- Timing belt slack
- What degree thermostat
- Steering feels weird (too light and free)
- Gear Shifter locked [solved]
- Cold start idle near stalls and fluctuates
- 98 Civic EX is this noise bad?
- ICE freezing door lock actuators / lock cylinders
- 1996 Civic CX Fuel Level Sending Unit
- 98 Civic ex no fire at plugs
- Car doesnt want to turn while braking.
- 98 Honda Civic LX - STALLING MYSTERY
- D16Y8 making a weird noise
- Identify this piece please
- 1999 Honda Civic EX
- suggested buys for 1.6 KE D-series oilpan gasket repair?
- new guy
- Cv half shaft questions.
- Throttle cuts out, no CEL light
- 1998 civic steering twitch???
- Honda Civic 99 Fuel Smell when tank full
- Honda Civic Dx 2000 doors wont lock
- Replaced power steering pump, grinding noise
- How should I go about fixing this exaust leak
- Sputters but no start
- what is an acceptable fuel pressure drop when my car is turned off and sitting?
- Fuel pressure regulator question
- trunk leak 2000
- *Solved (Long) High beam indicator light stays on '99 EX
- Fuel Economy Dropped 25% After New Air Filter
- Runaway idle
- Hard to put in 1st or reverse 5 speed standard
- Engine locked up!!!
- Black soot from exhaust 99lx
- ABS light on after battery reconnect (MB1/D16Y3)
- Turn Signal Staying On When Braking
- code 1457
- Auto Tranny Fluid: Flush or Change?
- Not your typical surging issue
- 96 Civic A/C Condenser Fan Connector Diode Specs
- Wondering if it's over - issues around misfire
- Need info about the rear brake line on the passenger side
- Resurface the head or not
- 98 civic ex has no 🔥
- Do I Need a New Fuel Tank?
- 1998 Ex climate control not working at all
- Looking for part number for the exterior window trim (belt molding)
- New head gasket repair smoke
- Crankshaft Positioning Sensor
- Brake scraping? Or something deeper
- Ignition switch
- Exhaust pipe at resonator corrosion...
- 97' EJ9 Front Collision Damage Restoration (Help)
- 97 honda civic, starting issues, runs fine once started
- I have a 2000 honda civic and i have a idle sugre
- 2000 Honda Civic EX 5spd cranks/no start
- Shaking/vibration on steering wheel at highway driving
- How to determine AC System oil level
- No power steering after rear engine mount replaced
- Car will not start, it's not getting any fire
- Power steering
- D16y8 stalling out when gas pedal is pressed
- Rocker panel molding clip
- Emissions stuck in monitoring
- '96 connector mystery
- Restore a 96 Civic EX Coupe Back to Life
- Cars not running right
- y7 block/ y8 vtec sohc head, crank tdc problems
- A/C Leaks: UV Dye Is The Way To Go
- A/C: Pulling Evaporator, Replace Expansion Valve?
- Vacuum Pump OIl
- A/C Repair: Leak Dilemma
- A/C Repair: Why So Many Seals?
- Gasket matched head and intake manny issue w/idle
- Oil Viscosity Advice
- 2000 AC rebuild issues
- A/C Repair Advice
- Can you tell where the leak is coming from
- Transmission slip
- 2000 Honda Civic EX Odd Suspension Rattle
- 99 Civic DX Automatic Door Locks
- Oil light on after removing bad speed sensor
- Crank no start
- Need to do the clutch, and soon a timing belt.. pull engine and trans?
- I have a 99 civic LX. How com there are so many different timing belt tensioners?
- Ac not cooling well
- Help engine bogging
- AC compressor change/overheating
- Install new emblems
- Timing Belt Loose & Fraying
- Catback on honda civic 98
- MT with AT codes
- Engine cutting out randomly, no CEL, very detailed symptoms
- 2000 LX. Misfire Codes when starting HOT
- Distributor cap and rotor replacement
- Does this pop off?
- speed sensor?
- Burning Oil
- How 2 Remove Rubber Spark Plug Tube Seals
- Surging while accelerating? (97 civic hx)
- Idle control valve hoses locations ?
- Car starts, won’t start or just shuts off while driving
- 1998 civic ex error code fuelsys1 ol fault from autel scanner
- 2000 DX turns over but will not fire
- 99 Civic LX not starting/weird noise
- Identify this part
- Honda civic lxi 1996 ac compressor
- Replace front exhaust pipe
- Bad bearing noise. Help
- Won't start
- Possible water leak?
- A/C idler pulley problem
- Honda civic lxi 1996 cabin air filter
- 1999 Civic EX Cylinder 4 misfire issue
- Need transmission advice!
- 98 Civic with K swap; AC isn't working as it should
- Transmission needs some pumps in the clutch pedal to switch gears smoothly
- 1999 Si dome light problem
- ‘99 Civic LX automatic transmission...high rpm when changing gears
- Will not having a clamp on the fuel line to the manifold cause acceleration issues
- Fuel injector problem
- D16y8 valve noise
- Cooling system problem
- Just wont move !!!! NEED HELP
- Name of this plastic clip
- Keyless entry
- Where does air go from filter?
- Running without a thermostat
- 99 si. wrecked- rebuild hard?
- 1999 Honda Civic Cranks but no Start
- Problems with new instrument cluster
- Turn Signels Problems
- Error Codes P1768 P1298 P0135 P0141
- Question about crankshaft
- Noise from engine
- 1998 Civic repair estimates - looking for some advice
- Misfire/Distributor issue
- Problem with Idle
- Intermittent Shaking
- Blinking/Flashing battery light [SOLVED]
- Shift linkage flipped upside down somehow.. please help
- Won't start
- Messed up timing!
- Oil Pan and Gasket Replacement
- Oil in Coolant, but not coolant in oil?
- 2000 Honda Civic EX (Canadian) Won't Start When Very Cold
- differential bearing is dead, transmission rebuild?
- Alternator dead - How hard to replace?
- Crank, no start
- 2000 Civic Exhaust Gasket Crack
- High pitched whistling noise 98 civic ex
- Em1 CTR headlights
- Crazy speedometer and engine light help
- Check engine light on due to o2 sensors
- d16y8 start up/ rev issues
- Oil control office and o-ring D16y8
- D16Y8 Headgasket replacement
- Valve cover bolts and new grommets, how to get them on?
- Crank snout and woodruff key
- Gas milage SUCKS!!
- Exhaust connection problem
- Is this missing a cap or hose?
- Just picked up a 2000 EX Coupe - Weird loud buzz while driving (Video Inside)
- Intake resonator... is it needed?
- ‘00 EX distributor oil Seal vs. O ring
- P0420 code
- 2000 Honda no spark
- Integra B20B high idle
- 1996 Civic IACV High / Surging Idle Issue - Long Read...
- New Seat Help
- ARP Head studs / Gasket kit - Worth it?
- Fries batteries
- 2000 Civic LX drops to 23 MPG
- 1998 civic was stalling but now it wont stay running
- No interior lights
- 2000 civic misfire
- 96 civic won't start
- Civic 2000 EX - OBD2 fuse location and P1456
- Plz help finding manifold heater connector
- P1106 help 98 ex auto to manual swap
- Aftermarket distributors
- P0308 Codes but it's strange
- 1999 Ex idle issue
- electrical problem 1997 civic ex
- Manual 97 civic LX
- 98 Hatchback door lift
- 2000 Civic Auto trans slip
- 97' Honda Civic will not change gears
- Cooling system woes.... again
- Starting issue...
- D16Y7 Interference or not?
- high, surging idle
- 2000 Honda Civic ex 4door wont start
- Camshaft seized cam gear still spins.
- 99 ex misfire bog problem
- 1998 hatch 5 speed wont change gears
- What part does the thermostat connect to on a 97 civic?
- No speakers work now... :(
- Car stalled and now won't start
- Lugnut stripped...
- Axle seal leak
- 96 dx needs smog but 1st...
- 1997 HX Window Regulators
- Best radiator
- 96 Civic CX Read Engine Coolant Temperature via OBD2
- Cheap Manifold Replacement D16Y7?
- 92 Civic Ex steaming aluminum radiator
- Idle surge issue.
- 2000 Civic si dead cylinder help!
- VTEC Won't kick in
- how can i take mold out of my Honda?
- EGR CEL and misfires
- another idle thread, please help.
- 96 Civic loping on hills
- Unable to remove old blower motor.
- New Civic Owner/ Suspension Swap Compatibility
- Radiator and hose replacement 99 EX D16Y8 Engine Type
- Oil leak and exhaust smoke - D16Y8
- p0141 replaced the o2 sensor still code
- 97 Civic LX loss of all power no start..
- 96 EX cranks, wants to start, but won't.
- Coolant leaking from Valve Cover Gasket
- Holes drilled into gas tank; temporary fix?
- 99 ex
- Help please!!! D16y8 swap done issues
- D16A Clarification
- Replaceing inner & outer tie rods 96 civic ex
- Running lights, turn signals, and flashers not working...
- Power front door locks not working - any guidance please?
- Intermittent Dying Problem
- 99 civic keeps shutting off while driving
- '98 Honda Civic LX - Cooling Fan, A/C Fan, & Rear Defrosters Not Working
- Bad starter?
- 2000 civic ex stalling issue
- Idle issues and weird things with throttle
- Engine Mount Replacement 99 Civic EX
- Radiator Replacement 99 Civic EX
- Bad Thermostat or HG?
- windshield wipers won't turn off
- 96 Civic LX cranks but won't start
- 1998 Honda Civic EX P0302 P0304 P0300
- 2000 LX is hard to start
- 1997 - d16y7 p0401 code - Idle Surging
- b16b stuttering/sputtering
- good brand of fuel injector
- '99 LX Hard Shift / Thunk when shifting
- 98 Civic CX Misfiring at idle? (Video of symptoms included)
- o2 sensor and electronic load detector codes after installing ebay header
- Cost to repair air control valve
- Brake lines
