95 Civic DX AT fluid leak
Old Jun 7, 2025
itsmekd's Avatar
itsmekd is an unknown quantity at this point
After taking my car to 2 mechanics (I should have known better) they both said that my AT fluid leak was coming from my driver side CV axle seal. Well, my brother and I get under the car and check the seal and it’s perfectly fine. We replaced it anyway, which I normally do not do. It looks like the leak is around the lower bolt on the T bracket, actually. I believe that screws in to the tail shaft…right? Is that fluid retaining? I can’t find this info anywhere specifically for the 5th gens. Thanks in advance!
Old Jun 8, 2025
Colin42's Avatar
Re: 95 Civic DX AT fluid leak
I would think more likely its residual oil from removing the oil filter during an oil change if it's by the t bracket. Try cleaning it real good then driving to see if you can spot a leak.
Old Jun 8, 2025
itsmekd's Avatar
Originally Posted by Colin42
I would think more likely it’s residual oil from removing the oil filter during an oil change if it's by the t bracket. Try cleaning it real good then driving to see if you can spot a leak.
This is a significant leak, and it’s def transmission fluid. Every time I drive it, there’s so much fluid dripping on to everything that my car is smoking like a 4th of July bbq when I come to a stop. The fluid pooling around that bolt on the T bracket is red and the fluid dripping on to the oil mat & towels I have down is red. When I check my dipsticks, my oil is good, ATF keeps getting low. It’s in such an annoying spot to figure out but I love this girl and really want to fix her.
Old Jun 9, 2025
Colin42's Avatar
Coming out the dipstick or vent maybe?
trying to think whats around there that could leak
bigeg
Sep 11, 2023 06:35 AM
camaro1185
Jun 17, 2014 07:35 AM
biker275
Nov 5, 2013 06:48 PM
my89CIVICDX
Sep 27, 2013 12:55 PM
caper74
Nov 23, 2009 10:04 PM
