Help!!! Mystery misfire no start when hot not main relay
Old Jun 12, 2021
DrivenHonda's Avatar
DrivenHonda is an unknown quantity at this point
Hi so the story is that i can drive my 2000 civic honda but after parking and trying to restart it I have much trouble as seen in this video https://youtu.be/8dTBpuEjLew it will take several hours to restart the car and clear misfire. Only codes that come up are the code for random misfire. Any ideas thanks
I already replaced the
  • Intake manifold
  • Map sensor
  • Oxygen sensor 1 and 2
  • Air and fuel filter
  • Main relay for fuel
  • Exhaust manifold and cat converter
  • Muffler
  • Fuel pump
  • Battery
  • Distributor
  • Wires to plug
  • Spark plugs
  • Fuel Injectors
  • Fuel rail
  • Fuel pressure regulator
Old Jun 12, 2021
Re: Help!!! Mystery misfire no start when hot not main relay
Its not drivable until the "flood" clears I smell gas and hear the fuel pump prime but it has no power and i was pumping the pedal in video it has no pedal response at all
Old Jun 12, 2021
Wankenstein's Avatar
Solve a fuel flood issue:
Remove the spark plugs, press gas pedal to floor and crank engine to blow gas out of cylinders. Add a tablespoon of oil to each cylinder, reinstall spark plugs, crank with gas pedal to the floor.
Spark, Fuel, Air... are all three present in the cylinders?
It may be leaking fuel injector o-ring seals?
That would cause excessive amounts of fuel in the cylinder(s)
Pull the spark plugs and look and smell for fresh gas on them.
Only way to check injector o-ringsbis to pull the injectors and inspect the prints for tears or dry rot.
Old Jun 13, 2021
They were soaked with gas. I have what smells like gas in oil from it flooding.
Old Jun 13, 2021
Not getting proper ratios of air, fuel, spark in cylinders to burn off fuel. Do a power balance (rpm drop) test on it. 1st test: at idle slowly lift the spark plug wire off the spark plug (one cylinder at a time). If spark is good then rpms will drop when the spark wire lead is lifted farther away from the spark plugs. However, if lifting the spark plugs wire lead off the spark plugs doesn't cause an rpm drop then it's a sign of poor spark, poor compression or poor fuel injection. Do this test one cylinder at a time.
Do the same test again except do not remove spark plugs wires. Instead, remove the fuel injector harness one at a time on corresponding cylinder being tested. If rmps drop then fuel injection is good. If rpms do not drop then it's an injector issue Link: balance test ://troubleshootmyvehicle.com/honda/1.6L/how-to-do-a-cylinder-balance-test-1
Old Jun 13, 2021
Flooded cylinder causes: https://despairrepair.com/flooded-en...oms-solutions/
Old Jun 14, 2021
I replaced all the injectors and the problem disappeared for a day and now its back but not as severe. Should I suspect someone was vindictive with my gas tank?
Old Jun 14, 2021
Did you try the power balance tests yet?
Performed a dry and wet compression test on it?
Always test before replacing parts.
2hi4u
Engine start problems
Jul 20, 2020 11:45 PM
Tim69304
Oct 9, 2018 11:10 AM
kobeclutch2494
Mar 7, 2012 09:20 PM
scout206
Dec 1, 2010 09:29 PM
number4t1
Buy, Sell, & Trade - Archive
Apr 6, 2009 03:36 PM
