Fuse 15 but no power to (O2 Sensors + Evap Relays). How to fix?
Old Jan 25, 2025
morbly's Avatar
morbly is an unknown quantity at this point
This started as an O2 sensor Code, but whether it was initially really just an O2 Sensor problem or not, it is now a nearly complete disconnect from the fuse panel back to a bunch of functions that include the O2 sensors. My schematic says that a black and white wire runs from Fuse 15 to feed 5 different components; (both O2 sensors and all 3 Evap valves). Those 5 components each get a switched ground connection from the Powertrain Control Module.
The problem is not the ignition switch that supplies power to Fuse # 15, nor is it Fuse 15. I am getting 14.24 Volts to both sides of Fuse 15, and all those loads, combined, are only pulling 30mA. So the problem has to be the fuse panel connection to that B/W wire or that wire's connection to the group of 5 loads... or it could be that the wire itself is broken. The only one of those that I could foresee repairing would be the connection at the fuse panel. That is if I can somehow work on the fuse panel. I can barely see it. Can you remove the fuse panel? Are there big connectors that attach it to the electrical system, or are there individually connections?
Gpotzzz
Mar 18, 2022 06:36 AM
Hrddrvs
Apr 11, 2015 06:41 PM
jameslinkinpark
Sep 26, 2006 07:07 PM
funkycivic2k1
Apr 6, 2003 07:46 PM
WhosYoDadday85
Feb 19, 2002 09:35 AM
