Flashing check engine light
Old Dec 15, 2021
Lukarlov01's Avatar
Lukarlov01 is an unknown quantity at this point
I have a 1999 civic ex with a mini me swap. I was coming back from work over a bridge and went 95 mph in 4th gear at 6k rpms. After I got back down to 60 mph a flashing check engine light appeared and the car felt like it has a misfire or the engine shaking, the flashing check engine light would go steady then flash again pretty intermittently, I don’t have any loose hoses or any loss of coolant or oil or any leaks of any kind. My oil isn’t milky so I don’t believe it’s a head gasket but my spark plugs has a bit of oil on the threads and are a bit white/brownish, I know I have a bad IAC valve my idling is real bouncing in first and second gear. My distributer is somewhat new and same with the spark plug wires from what I can tell, I bought the car about 2 months ago and I’ve only put an exhaust on it. Any one want to help me narrow down my search for the problem at fault before I start throwing parts at it? This car is also my daily driver.
Cylinder 1 left plug, cylinder 2 right plug
Old Dec 16, 2021
Re: Flashing check engine light
check the codes.
don't go driving at high speeds in the streets, there are plenty of track days where you can do it safely
Old Dec 16, 2021
Lukarlov01's Avatar
Originally Posted by sdaidoji
check the codes.
it was in Mexico
Old Dec 16, 2021
Colin42's Avatar
Sure it was....
flashing light usually means a misfire
Aviator66
Feb 3, 2020 12:34 AM
htc1x
Feb 23, 2017 08:29 PM
robber
May 3, 2009 04:36 PM
ryancivic
Jun 13, 2006 09:57 AM
bluecoupe
Jan 23, 2002 05:50 PM
