no spark
Old Oct 30, 2011
fiftyfone's Avatar
fiftyfone is an unknown quantity at this point
no spark
I have a 1995 honda dx with the 1.5 non vtec engine. I replaced the clucth and pressure plate when put it back together crimped the wire from the o2 sensor in the case. after trying to start with no luck, found the wire and removed the wire from inside the case. now i'm not getting any spark from the distributor. I have replaced the distributor, the cap and rotor. took the ecm out and put in another civic it started right up along with the distributor, main relay under the dash.all started fine. checked the fuel pump and it whirrs when the key is on but constantly.corrected the wires for the o2 sensor. I have battery voltage at the blue and yellow wire going into the distributor. No other ideas, any would help.
Old Oct 30, 2011
JohnHenry's Avatar
R.R. Adict
JohnHenry is an unknown quantity at this point
Re: no spark
When you crimpped the wire, was the battery disconnected???
Old Oct 30, 2011
fiftyfone's Avatar
Re: no spark
yes, I tried to start it. now the engine turns but wont start, checked the plug wires at the distributor and there is no spark.
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
Bman2212
Sep 2, 2015 11:49 AM
