Click no start after starter replace
Old Oct 23, 2020
jf42's Avatar
jf42 is an unknown quantity at this point
Cool Click no start after starter replace
Hello all,
I have a 1999 Honda Civic DX manual transmission that i recently did a clutch job on as well as a starter replacement, as it had died on me (bench tested to confirm). Now i have the new starter installed. When the key is turned the starter solenoid clicks once and the starter doesen't turn. Battery seems to be working as the headlights don't dim and i recently charged it to full. The dash lights also don't turn off when you try to crank. The ecu and clutch sensors also seem to work because the fuel pump kicks on after you turn the key, indicating that it thinks the engine is running (cel also comes on). The engine is also not locked up and can easily be turned with a socket. The new starter is a Bosch rebuilt unit (SR1309x). Any help would be appreciated.
Old Oct 23, 2020
BrotatoChip's Avatar
Super Moderator
Re: Click no start after starter replace
A few things:
-Measure battery voltage while trying to crank, shouldn't go lower than ~10V.
-Verify you installed the starter correctly. All wiring hooked up?
-Verify battery voltage on the main starter cable. Verify battery voltage on the solenoid wire when ignition turned to crank.
If all of that checks out I would lean towards a bad starter.
Old Oct 23, 2020
jf42's Avatar
I did all the tests and they checked out so bench tested it. looks like CARID sent me a bad starter. Thanks for your help!
Legofan
Jul 19, 2020 08:46 PM
g4384063
25
Dec 14, 2017 10:54 AM
2003civlxhockey
Florida
Jan 22, 2014 07:20 PM
Fatal_Error
Jan 27, 2011 09:57 AM
Deu
May 11, 2002 04:34 PM
