D16A cylinder 2 misfire
Old Dec 9, 2019
Shane Fickett's Avatar
Shane Fickett is an unknown quantity at this point
I have a 1996 Civic with a D16A, and started getting misfire code while driving home the other night. I replaced the cap and rotor, ended up replacing distributor as well (can sensor and ICM are new now because they are in distributor) new plugs and new plug wires and I tested crank sensor, but I’m still getting misfire in cylinder two. For some reason my distributor is not sending spark through the cable to cylinder two. It did the same thing with the old distributor, I tried the old cap and the old plug wires and moved them around and still no spark for cylinder 2. It’s driving me crazy. What would cause the distributor to not send spark to only one cylinder when all the ignition system parts have been replaced and are new? Someone please help, I’m beginning to think it’s the ECM itself.
Last edited by Shane Fickett; Dec 9, 2019 at 04:09 AM. Reason: Title change for more viewers
MrShorty
Jul 25, 2019 06:24 PM
Sarahg9106
General DIY
Jan 15, 2013 09:04 AM
bambino3710
Oct 31, 2011 11:07 AM
97 Civic coupe
Sep 27, 2010 09:13 PM
fondahonda
Sep 6, 2006 06:18 PM
