98 LX High Idle with p0122 code
Old Sep 4, 2019
JWelk92's Avatar
JWelk92 is an unknown quantity at this point
Hi All,
New here as well to owning a car. I was gifted a 98 Civic LX from family with new breaks, break cables, and ac. However, it idles around 2k to 2.5k and my obd2 reader has code p0122 Throttle Position Sensor ‘A’ circuit low voltage. We bought a new sensor and checked that the wires were completing a circuit with a light and probe (sorry I don’t know technical terms yet). The code is still present but when the MAP sensor was unplugged idle went down to just over 1k or if the throttle cable is pulled off the pulley to artificially lengthen the cable it will idle around 1.5k. I could really use some guidance on my first car.
Old Sep 4, 2019
Matt3civic's Avatar
Matt_Y
Matt3civic is an unknown quantity at this point
Re: 98 LX High Idle with p0122 code
Have you put an ohm meter on the tps and made sure it’s within the correct volt parameters? Maybe it’s .5v at an idle 4.5 at WOT?
Supreme_One
Jul 12, 2023 07:36 PM
Klaula86
Oct 24, 2017 07:02 AM
streetglower123
Feb 17, 2015 07:28 PM
ST8RACE
Jun 9, 2007 07:10 PM
blckpwdr
Dec 1, 2003 09:52 AM
