99 Civic overheat
99 Civic overheat
I own a 1999 honda Civic EX and have been having overheating problems since February. I've replaced the themostat, most hoses, the radiator, the water pump, timing belt, and the head gasket. The coolant has been at the same level for the past few months, but yesterday I was driving in from Houston to Galveston and noticed my car was extremely slugish. To the point where I had to basically floor it to get good speed. After a while I noticed the gauge was starting to rise. It mostly happened when I was either slowing down or in idle. I have no idea what this could be.
Re: 99 Civic overheat
on hot days and slow traffic it's not uncommon for dash temp needle to raise between half and almost 3/4.
radiator fans can be slow to engage sometimes.
What you described in your initial post is probably not that concerning unless it keeps happening or it starts to lose coolant.
What procedure did you use to bleed air from the coolant system when you did the other repairs?
What procedure did you use to bleed air from the coolant system when you did the other repairs?[/QUOTE]
kept the radiator cap off when running and filled it up more when the coolant started to go down. Did that until it was full.
1) Raise front of car on jacks (or incline hill) as high as possible (radiator cap/neck higher than top of engine)
2) set interior climate control to max heat and fan off
3) bleed (from cold start) with radiator cap off at idle until radiator fan engages or no more bubbles are seen. Fill radiator and reservoir as needed during bleed procedure.
4) after bleeding air from system turnoff the engine and let it fully cool. While engine is cold check the coolant levels in radiator and reservoir, too up as needed.
5) Check coolant levels everyday for a week to ensure no coolant loss.
Improper bleeding of air from the coolant system can lead to overheating, rough idle, erratic cabin heat via climate control.
Treyson
15
Aug 23, 2020 04:11 PM
Dccoleman
Jan 4, 2020 02:54 PM
joe85sti
Jun 19, 2018 09:57 PM
GloveBoii
Jun 20, 2012 11:27 PM
