Power loss/hesitation P1362 code [solved]
Old Feb 25, 2021
PomerJoN's Avatar
PomerJoN is an unknown quantity at this point
I have a 2000 Honda Civic EX Manual trans and its had a weird stumble hesitation while accelerating (usually around 3k rpm) and feels really weak going up hills. Got a code reader and came up with just a P1362 code and from what I have read the sensor it refers to is built into the distributor, so I bought a new distributor and the issue didnt change and the code came back. When I bought the car there was some sus wiring and I discovered that a remote start was put in but had been disconnected. Is there somewhere in the wiring I should check that might be compromised and cause the sensor to throw that code? or can something not related to the distributor throw that code?
Old Feb 25, 2021
re: Power loss/hesitation P1362 code [solved]
trace all the wiring and check for issues
Old Feb 26, 2021
Wankenstein's Avatar
Honda genuine or aftermarket distributor?
Old Feb 26, 2021
PomerJoN's Avatar
Aftermarket from carparts.com
Old Feb 26, 2021
Colin42's Avatar
Fail, need to use an OEM distributor
Old Feb 26, 2021
PomerJoN's Avatar
Is the distributor for a non Vtec engine different then Vtec engine?
Old Feb 26, 2021
FRSam's Avatar
Click Here
Multiple sources confirm the part numbers to be the same, so they won't be different.
To elaborate more on what Colin's saying, Honda's are notorious for not cooperating with aftermarket electronics. Sensors, alternators, distributors, you name it. That's why he's suggesting you get OEM. They're guaranteed to work.
Old Apr 8, 2021
PomerJoN's Avatar
Well I bought a OEM dizzy, installed and cleared the codes and the code came back as soon as I turned the engine over. I think I might bite the bullet and replace the engine harness. I know the previous owner hacked into stuff to install a remote start and a little red led by the cluster. So who knows what else he did. There is electrical tape on almost all the wires going to the dizzy plug, and some electrical tape on some wires right where the harness clips into the ECU.
Old Jun 4, 2022
EliminatorEli's Avatar
EliminatorEli is an unknown quantity at this point
What ended up being the issue? I have a 2000 GX with similar issues. Very very weak going up hills. High fuel consumption, and several codes including misfires
Old Jun 4, 2022
PomerJoN's Avatar
yours sounds like it might be a clogged catalytic converter. I put a test pipe in mine and got some power back cause my cat was clogged, but my CEL issue ended up being a bad ECU. I got a matching used ECU and my TDC engine codes went away.
Old Jun 4, 2022
Re: Power loss/hesitation P1362 code [solved]
ECU?!?
weird case... not normal in 6th gen cars
regardless, glad you found the cause!
Old Jun 5, 2022
you could be right. I've heard an exhaust rattle back there. Just wouldn't have thought with a CNG vehicle, the cat would clog even being as old as it it. Going to investigate that and check feed on some sensors.
bsmiley
Mar 1, 2023 08:14 AM
treborabc
Electrical
Jan 16, 2022 09:25 AM
free_refil
Mar 23, 2010 08:46 PM
kx250ryder
May 18, 2009 03:13 PM
newellsb
Nov 19, 2007 03:11 PM
