Cylinder Head Replacement For P1361/P1362 Code
Old May 14, 2009
kx250ryder's Avatar
kx250ryder is an unknown quantity at this point
New to the forum, glad to see 155 people accessing the 7th Gen Civic info as I type this.
I am looking to do a cylinder head swap (per TSB 01-083), as I have subject MIL codes, and changing the TDC sensor did not help.
In order to source my cylinder head, I need a "cast number". I didn't want to tear the car apart until I had the parts in hand, but need to know where to locate this number for the order. Please be as specific as possible to its location, as I am new to Civics.
Thanks!
Old May 18, 2009
kx250ryder's Avatar
Re: Cylinder Head Replacement For P1361/P1362 Code
Found it. For anyone wondering, stamped into the head directly above the exhaust manifold. In my case "PLC-8" (or maybe 3, it isn't all that clear). From what the vendor said, its the PLC that matters, not so much the number.
I will be tearing the motor down, and photographing everything to create a DIY cylinder head swap tutorial to post. While I'm at it I'm doing the timing belt and water pump as well.
I did cheat a little though, as the replacement cylinder head I ordered already has the valves installed (remanufactured).
thana
Jun 15, 2020 07:05 PM
deus-ex
Apr 13, 2015 12:29 PM
thesushiboy
Apr 12, 2015 02:54 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
