Cluster temp gauge spiking
Old Jul 31, 2019
Newbuild's Avatar
Newbuild is an unknown quantity at this point
Ok guys i need some advice....
My water temp gauge is spiking once it reaches operating temp. I've replaced ect sensor, fan temp switch, radiator cap, and thermostat. No loss of fluids or fluids being pushed into the overflow... I've checked water pump for circulation and leaks and its working properly with no leaks.... I've tested the above mentioned sensors and they work. I've even removed the thermostat and tried running the car without it but gauge in cluster still spikes out too hot... any help or advice would be appreciated.
Radiator fan works when shorted out but cant get it to turn on with the sensor plugged in and car is idling...
Old Aug 1, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Cluster temp gauge spiking
Might be a voltage spike if some sort.
If the temp sensor was replaced with on OEM part, them my next test would be looking at the voltage at the gauge.
vichonda
Electrical
Feb 24, 2020 12:21 AM
99hondamar
Aug 27, 2017 07:49 PM
Rushfan1
May 6, 2015 01:20 PM
themovielife
Mar 23, 2011 06:42 AM
Thornedleaf
Buy, Sell, & Trade - Archive
Mar 22, 2007 02:34 PM
