95 civic fuel issue
Old Mar 7, 2019
velozp's Avatar
velozp is an unknown quantity at this point
95 civic fuel issue
Hello guys my 95 civic lx sedan is having issues. You tube videos show 2 possibilities PGM FI MAIN RELAY or MAIN FUEL RELAY solder issues. Is this the same part? And locations would help. The car will intermittently no start ( not the no start distributor sound, doesn't get to full crank) Its definitely fuel related. I did replace the fuel filter. After a few tries it starts fine. And one time it started, I let it run 5 minutes, as I backed it iout of the garage it stalled then started again. Its very intermittent.thanks
Old Mar 7, 2019
Wankenstein's Avatar
Re: 95 civic fuel issue
Make sure all grounds are connected and tight. Someone just had a similar incident and stated the water inlet housing ground was loose and caused intermittent starts.
tgaffner
Apr 4, 2015 01:59 PM
Guillen21
Jul 27, 2013 11:12 PM
timmerz
Jan 11, 2012 01:22 AM
koisser6284
Aug 4, 2010 07:34 PM
ShawnTRD
Jul 4, 2010 11:24 AM
