1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Fuel issue?
Old Jun 28, 2010
ShawnTRD's Avatar
ShawnTRD is an unknown quantity at this point
Fuel issue?
OK First I've had my 95 for 2 years , and I always turn my key on and wait till the CEL (Check Engine Light) goes off before starting it. And it would always start right up strong. When the CEL is on I can hear that I believe is the fuel pump. When the light goes off the pump goes silent. Lately I've been noticing when I stop at a store and go to leave shortly afterwords (less the 1hr) the car starts and idles really low and seem like it's starving for fuel or flooded out. Twice now I gone to start the car and the CEL doesn't go off, I can't hear what I think is the fuel pump, and when I try to start it she won't start.
So is it a pump going bad?
A fuel relay? If so where is it?
Something else?
Old Jul 1, 2010
bk7794's Avatar
bk7794 is an unknown quantity at this point
Re: Fuel issue?
Can you hear the relay? if so then the fuel pump could have gone bad. One way to check is to first see if the pump is running or fuel is atleast getting pumped to the engine. To do that do a simple fuel test.
http://www.youtube.com/watch?v=mdpP4wxBvpA I found that video really helpful. If it comes out weak or not at all and you hear the main relay then you know that its okay. If you dont hear the main relay. Then you got anther problem
Old Jul 1, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Fuel issue?
Get your CEL code checked. It will more than likely tell you what the problem is.
Old Jul 2, 2010
ShawnTRD's Avatar
Re: Fuel issue?
Picking up a relay today from Advanced for $30 (coupon for $20 off $50). If that doesn't work I'll be back.
Old Jul 2, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Fuel issue?
Why do people change random parts on a car without getting the CEL code read? You probably just wasted your money. Go get the code read, then change parts.
Old Jul 4, 2010
ShawnTRD's Avatar
Re: Fuel issue?
K well I change the relay Friday. At first I was thinking it wasn't the problem. Seemed like I still had the same problem with rough idle (for 5 seconds) when hot. But I've been driving around and it looks like it might be getting better. I will see how it goes this week.
dpru
May 26, 2015 07:01 PM
werdnahall
May 17, 2015 11:37 AM
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
PerfectD3
Feb 17, 2002 03:59 AM
