1998 honda civic hatchback 1.6l d16y7 automatic transmission P0335 code
Old Jul 26, 2020
Mojito1983's Avatar
Mojito1983 is an unknown quantity at this point
Hi everyone am new lol. Thank you in advance for all of your help. Here is the deal the car was running fine and I stopped to pay a toll as soon a I pulled forward I felt the car has lost some power then shift to second gear really hard then 3rd same thing hesitating to shift but then I realized that the car would not go over 35mph turn around came home hooked the obd2 scanner and gave me a p0335 code I replaced it same thing I replaced the fuel filter worked for 3 miles and same thing new plugs new wires catalytic converter is empty change the upstream o2 sensor and finally replaced the ecm from a junkyard same part number car idle ok PLEASE HELP I CAN'T AFFORD A CAR I HAVE TO FIX THIS ONE also check wires as much as I could and I don't see anything obvious thanks again.
armando19846
Transmission
Aug 14, 2019 12:46 PM
davidpaustin
May 7, 2015 05:08 PM
x3nzox
Mar 7, 2013 08:25 PM
clpowell
Feb 19, 2013 12:37 PM
