00 civic ex no start no crank
Old Jul 15, 2020
hfalz123's Avatar
hfalz123 is an unknown quantity at this point
I have a 00 Honda civic ex manual trands, has been sitting in garage for aprox 5 yrs. No crank no start. Just put a new batt. and starter in it. All lights and electronics turn on in on position. when i turn the key to start all electronics and a/c turn off. checked the oil looks good. two back running lights stay on even when i take the key out of car. reg. low beam lights work when i turn the highs on they are dimmer. checked all the fuses and all are good. brake lights do not work. trying to get it running so i can take it to a mechanic to try and fix. any input would help.
Old Jul 16, 2020
Colin42's Avatar
Re: 00 civic ex no start no crank
check the brake switch and the clutch switch.
Also check the electrical part of the ignition switch
Old Jul 21, 2020
BeeSeries's Avatar
BeeSeries is an unknown quantity at this point
No crank but battery and starter are new, check your grounds or ground wires for corrosion. Transmission to frame, back of the water housing and valve cover. Are you getting an audible click/pop from the starter with key fully turned. If you have 12v at the starter with key to crank then you have bad grounds.
Old Jul 23, 2020
JBDesigns's Avatar
JBDesigns is an unknown quantity at this point
Check ignition for spark as well as fuel. Can you hear the pump prime?
Old Jul 23, 2020
hfalz123's Avatar
That was the problem! Thanks!
Andrew Kubik
Nov 6, 2019 07:19 PM
ianator13
Engine start problems
Dec 7, 2015 08:09 PM
slooger99
Nov 24, 2012 02:07 PM
mikekellog
Sep 15, 2007 08:49 PM
o2civic
Sep 7, 2005 02:14 PM
