Troubleshooting won't start
Old Sep 15, 2007
mikekellog's Avatar
mikekellog is an unknown quantity at this point
I have an 01 Civic EX AT.
When I turn the key, it won't begin to crank. You can hear the relays working 'clicking' up front and it also appears that something is clicking in the ABS pump brake area (Probably normal)
I checked the fuses up front and they look good. I swapped all of the relays around in case one burned out and still the same. EXCEPT the big silver one since there isn't an equivalent that I could swap out. (It looked fine though)
I looked at the fuses underneath the driver's side and they look good. Battery terminal was reset and/or ECU fuse reset.
The ones in the driver's side seems to have more wear and tear than the fuses up front, but I took the spare 15A fuses from up front, and put them in the ig coil and fuel pump just in case. I was trying to swap the relays around underneath, but couldn't get them to be very well accessible and I thought I'd post first.
I don't think it's the battery, it won't even try to crank. The lights and radio and power windows work well.
This is with the Honda key w/ the immobolizer etc...
Car has 135K miles, and it has shown similar behavior a couple of times before. What has happened, is you'll turn the key and car won't start but you'll hear a whole bunch of relays going nuts.. trying again would fix it, so maybe it finally broke now..
I have also had the 'maintennce required' light for a while but I figured it's because I haven't changed the oil in forever. The cad had been sitting prior to this but it did run just fine for a few days.
Thoughts? Help is appreciated since this is my daily vehicle.
Old Sep 15, 2007
greeen01civic4d's Avatar
Re: Troubleshooting won't start
prolly the starter, if it just clicks, and doesnt turn, all u gotta do is replace the starter, done
Old Sep 15, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
yup yup, that is my guess.... how do u check your starter?
Old Sep 15, 2007
have it tested by an auto parts store
Old Sep 15, 2007
speedfoos's Avatar
Have you checked for corrosion on your terminals?
We have a voltage sensor on our cars and if it detects lower than a set amount when starting all you'll hear is a "Krrkrkkrkrkk!" and it won't let the starter engage. Happens to my wife's truck about every six months. I just have to clean the gunk of the terminals and battery posts and it's good to go.
Old Sep 15, 2007
sounds like a dead battery to me.
Old Sep 15, 2007
BlackieEM2's Avatar
BlackieEM2 will become famous soon enough
i say check ur starter or battery, if both are good, i say check carbon build up
Old Sep 15, 2007
speedfoos's Avatar
Carbon build up? On what?
If it won't even turn over, there isn't any juice getting to the plugs to even fire them. Carbon build-up has nothing to do with this.
Old Sep 15, 2007
jakes01civic's Avatar
jakes01civic will become famous soon enough
i had the same problem a few weeks ago. pull the ignition switch off but keep it plugged in to the harness. keep the key in the ignition and try to start the car with a screw driver by turning the ignition switch. mine started when i did that.
Old Sep 15, 2007
whattt??????? lets not go crazy now^^^
Old Sep 15, 2007
well it works lol. thats how people steal these cars. immobilizer doesnt even work cause technically there is no "wrong key" in the ignition.
Old Sep 15, 2007
mikekellog's Avatar
Thanks. I'll give these ideas a shot.
CarStuff
Dec 6, 2020 12:52 PM
redej2
Apr 29, 2015 01:47 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
