Bolt broke off in block for water pump
Old Sep 22, 2019
bigtunadaboss's Avatar
bigtunadaboss is an unknown quantity at this point
The shortest of the 4 broke off in the block. I'm pretty sure its tight and I don't see how you could remove it without pulling the motor out. And it is very deep in there. Not even sure how it broke because it wasn't even tight yet just snapped. Has anyone just only used 3 bolts for the pump? And what exactly is the torque spec then?
Old Sep 22, 2019
Re: Bolt broke off in block for water pump
okay well good news. I took the pump back off and because like stated earlier I wasn't even tightening it there was literally no part of the bolt showing but i just used a magnet and it unscrewed like that. Does anybody know the bolt size for it?
Old Sep 24, 2019
Wankenstein's Avatar
You will need to know bolt mm size, length and pitch. Search HondaPartsNow: https://www.hondapartsnow.com/
Old Sep 27, 2019
Hey so I got a metric bolt but putting headgasket on it doesn't seem like its for this y8 head? https://www.hondapartsnow.com/genuin...1-p2j-004.html
I have that one but it has extra spacing around it that appears to go out of the block?
mark2w1
Oct 5, 2019 08:47 PM
Pi653
May 14, 2018 09:38 PM
Kristoliquid
18
May 27, 2017 08:12 AM
CivicN3wb
18
Apr 17, 2012 01:59 PM
VA_Civic
30
Feb 21, 2011 03:51 PM
