Hose diagram, help!
Old May 10, 2018
IHellsent's Avatar
IHellsent is an unknown quantity at this point
Hose diagram, help!
Hey guys,
I recently picked up a d16y8 2000 civic ex stick. I did the head gasket but now I have no clear what goes here. Here's the pic
Old May 11, 2018
Wankenstein's Avatar
Re: Hose diagram, help!
That part doesn't look stock. Maybe this read will help: http://crxcommunity.com/viewtopic.php?f=4&t=62941
Old Apr 7, 2020
Zack Rorick's Avatar
New Member
Zack Rorick is an unknown quantity at this point
Originally Posted by IHellsent
Hey guys,
that hose goes from that to back of value cover. You see on intake manifold by valve cover
Old Apr 7, 2020
New Member
See
Old Mar 28, 2022
00hondaauto's Avatar
00hondaauto is an unknown quantity at this point
Originally Posted by Zack Rorick
See
I have a 2000 ex automatic and got rid of the metal pipe and put in a plastic connector instead. the pipe was hitting my aftermarket intake manifold with one port, i need to know if coolant runs through the one and if so is it going to get hot enough to melt the plastic splitter? and the automatic has a different setup from my understanding? so the tube that comes from the intake goes into the sensor off the block right which is what the metal tube connects the two together then the other sensor would be in the thermostat and comes from the top of the manifold like the picture then that sensor on the automatic has another pipe that comes off it and connects to the intake tube with its own tube/vacuum line correct? my question is can i use a 3 way split here to connect the block breather and the one that comes off that sensor on the thermostat into the intake tube??
or in other words the pic that says here has another port/tube and connects directly into the intake tube by itself correct?
and with the aftermarket intake being bigger i couldnt fit the metal piece in there so i used a 3 way T that connects the vacuum from the thermostat like pic to the intake tube so the 3 way connects the valve cover vent to that.
Old May 11, 2022
can nobody help me with this? the automatic is different i just need to know if there is coolant through them or if i can vent them and not throw codes please?
Old May 11, 2022
BrotatoChip's Avatar
Super Moderator
Some pictures of your specific issue would be helpful.
Old May 11, 2022
Colin42's Avatar
This 100%
Hondaguyej8
Mar 29, 2018 10:58 AM
Sean Perkins
Feb 15, 2016 09:34 PM
majikman
Bolt-on Engine Performance
May 27, 2014 07:12 PM
BigBear8080
Aug 26, 2012 10:07 PM
alstare
Jun 1, 2009 10:14 PM
