Blown headgasket?
Old Apr 9, 2021
Mycarisbroken's Avatar
Mycarisbroken is an unknown quantity at this point
Blown headgasket?
In my 1998 honda civic si (canadian) I have completely clean oil and it seems like completely clean coolant, the only thing is I have to constantly top it up due to a lot of pressure and I'm assuming its going out through the reservoir? When I've let it sit for a day it still has a lot of pressure in the radiator and I'm wondering if that would be good enough to assume a blown headgasket, there are no leaks under the car, I've put paper under it and everything. It also misfires a bit during a warm start, I'm not sure if these are related or not though, any help/opinions are appreciated!
Old Apr 9, 2021
BrotatoChip's Avatar
Super Moderator
Re: Blown headgasket?
Usually the D series engines don't mix oil/coolant when the head gasket goes bad. Combustion gasses leak past it and into the coolant system, that pushes coolant out into the reservoir and can cause it to overflow. The thread below is for the 7th gen but still a D series engine. You should be able to do the same tests.
https://www.civicforums.com/forums/3...reference.html
Old Apr 9, 2021
Alright thank you!
tifossi
Jul 14, 2022 03:19 PM
Jon Petersen
Jul 22, 2018 10:13 PM
BartusCompater
Dec 5, 2012 06:48 PM
bfairweath
Sep 8, 2011 12:08 AM
trurace
Engine Swaps
63
Nov 11, 2007 11:18 PM
