Stalling
Old Aug 8, 2019
Sleepy3rd's Avatar
Sleepy3rd is an unknown quantity at this point
Stalling
Thanks for opening this thread and your contribution is appreciated.
Bought new '98 LXSedan. 122K miles.
Driven locally, 20 +/- miles ea./4-5 days/wk by retired parent.
All regularly scheduled maintenance/worn part replacement performed.
RECENT CONCERN:
Engine shut-off and power steering loss during slow down/complete stop (most often after hill descent) at intersection.
RPM drops suddenly below idle.
Sometimes/not always with AC running on low fan speed. Afternoons 80s outside temp.
Intermittently, now - most recent (3) occasions during one 1/2 hour, suburban start/stop travel.
ALWAYS immediately restarts & proceed.
Air filter new. Housing removed and throttle body cleaned & torqued nuts.
VIN# not among ignition module Honda recall.
Key jiggle test did not replicate.
Honda dealership tech claimed 4 test drives around the block - no stalls. No precautions undertaken.
Fuel pump/filter/bad gas issue observed by anyone 1st diagnosis?
Any suggestions to provide my "not-Honda-dealership service" mechanic prior to scheduling appointment?
Cheers,
Jim
Old Aug 8, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Stalling
If its temperature related, then the temperature sensor should be tested. Make sure to use OEM sensors... it's not worth the headache to save $20 trying to use an off brand clone.
If the gauges are dropping before the engine stalls, look at the charging system.
Old Aug 11, 2019
Strick's Avatar
Strick is an unknown quantity at this point
Re: Stalling
Is this a case where the IAC valve is not operating normally? Any codes?
Old Aug 11, 2019
Sleepy3rd's Avatar
Re: Stalling
Strick,
Thanks for your reply/suggestion.
Ordered an engine coolant temperature sensor replacement to install Wednesday.
Will post results then.
All the best ,
Jim
Old Aug 13, 2019
Sleepy3rd's Avatar
Re: Stalling
Gentlemen (& Ladies)
SUCCESS!!!
Wear rubber gloves.
Disconnect battery (fan & electrical precaution always!).
Engine & all under hood area pre-degreased/steam cleaned.
Pan aligned below to collect coolant run-off (10 oz here)
Pliers to remove sensor.
Ratchet with 3/4" socket & 4" extension for clearance.
Remove & Replace in 5 minutes. Re-attach battery.
Replace bled coolant.
Start.
Idle returns to normal.
Test drive & all good.
RESET CLOCK.
Thanks to "mac25" & "Strick" for replies/suggestions and see links below.
Cheers!
https://www.hondapartsnow.com/oem-ho...%2c5;et=2%2c5)
Old Aug 13, 2019
mac25's Avatar
Re: Stalling
Always nice when people get back to us about the results.
Thx
Old Aug 13, 2019
Sleepy3rd's Avatar
Re: Stalling
ALSO NOTE:
Removed ECT sensor contact and unit threads were blackened with carbon(?) despite fastidious maintenance.
AC button ON & Fan High-speed, and immediately - FRIGID! Haha
Slainte!
Bruce2
Sep 21, 2015 08:01 PM
sped89
May 23, 2014 06:28 PM
tmv2005
Nov 4, 2013 06:37 AM
civic_civilian
Sep 26, 2013 09:35 PM
cfahamilton
Jul 7, 2013 07:50 AM
