d16y8 crank no start. has fuel has spark.
I recently picked up a 89 honda civic hatchback. it was swapped with a d16y8, i got the ecu chipped. i have gotten the car to start great 2 times, the rest of the times i started it and it sounded like it was running on bad timing and would nit let me rev the motor. limp mode? Whenever we use starting fluid the engine will actually fire like it has fuel but it will backfire out the intake. i put new gas in it too. i checked the timing and it was fine. the belts were brand new. I opened up the distributor and there was a white powder in the cap as if there was some corrosion in there. i cranked it with a fuel line cracked open and it leaked which means it has fuel. i did a compression check and everything was perfect.
Re: d16y8 crank no start. has fuel has spark.
So mechanical timing is good, what about the ignition timing? The distributor is adjustable
Recheck firing order, the spark plug wires may be in the wrong order. Firing out of order will cause a loud noise in the intake.
Skaterforeva1
Jan 21, 2019 01:31 PM
Ozwald25
May 12, 2017 02:50 PM
Klame9420
Aug 13, 2015 06:00 PM
Matthewd73
Oct 1, 2012 12:54 PM
Mayan-Si
18
Nov 22, 2010 11:01 AM
