Sputters but no start
Old Jan 20, 2019
Skaterforeva1's Avatar
Skaterforeva1 is an unknown quantity at this point
Okay guys so this civic has me stumped. I bought it and it was very hard to start and sputtered once it did and it slowly stopped starting. I have replaced the ignition coil, icm, cap, rotor, plugs, timing belt, and headgasket. I also checked fuel pressure from the filter and it read around 35psi. The compression was 120-130psi on all 4. I have checked an it is getting fuel and spark. It will not even sputter when I try starting fluid but does sputter like its going to start when I play with the gas pedal. It did seem like it blew some starting fluid back out of the intake manifold though. I am stumped. Any ideas?
1998 Civic EX
D16y8
Old Jan 21, 2019
Colin42's Avatar
Re: Sputters but no start
timing off by a tooth?
Old Jan 21, 2019
clogged cat or exhaust?
Old Jan 21, 2019
mac25's Avatar
Dr Krieger of Modification
First check the actual cylinder end of the combustion cycle.
-Do a dummy check for all fuses and grounds, plus a volt test on the battery (or a load test if you can)
-pull the plug wires and look for spark.
-pull an injector and look for fuel, or at least smell the cylinders for fuel/look at plug end.
-also check to see if the cylinders are flooded with fuel
-pull the air filter box to see if squirrels jammed it up with squirrel bedding.
Once you can tell us if it is ignition, fuel or air, we can help a bit more.
Ozwald25
May 12, 2017 02:50 PM
Kevin.Sahib
Nov 24, 2016 10:52 AM
Pnutty209
Nov 26, 2012 02:36 PM
Mayan-Si
18
Nov 22, 2010 11:01 AM
ebarber
Aug 4, 2009 03:56 PM
