D15 Z7, engine shuts off when car slows down or comes to a stop
Old Nov 20, 2019
Sakib Kamal's Avatar
Sakib Kamal is an unknown quantity at this point
Hello,
I recently purchased a 'very used' 1997 Civic EK sedan with a D15Z7 engine. The car had high idle and kept revving high on its own. So went to the mechanic and did the following:
1. Replaced the IACV - result, car was still revving high although less frequently.
Pulled the car a little on the highway to 6k revs and the engine shut off with the Oil pressure and Battery lights on. Also this time the Check engine light came on and it stayed on. Went back to the workshop. Checked the code and it was a bad throttle-body sensor ( the one at the bottom of the throttle body).
2. Replaced the throttle-body - result, no more problems related to auto-revving high.
However, found some leaks on the intake so replaced the seals and engine noise went down by far. The car felt nice for a few seconds that I drove. It feels smooth compared to before.
Now the engine keeps shutting off when I get off the throttle, or slow down, or come to a stop. When cranked, it turns on again. I can feel that it's a tuning issue, but we've spent hours tuning it. It doesn't shudder or shake, I tried increasing the Idle a little on my own and still it keeps shutting off.
My mechanic suggested that the engine needs to be replaced.
So I'm calling on all the Honda Gurus. Please help me understand what's wrong with this engine. I read on a different forum that it could be the MAP sensor. I haven't explored that yet.
Would really appreciate your input.
Thanks
Old Nov 21, 2019
GolNat's Avatar
Prelude Owner
Re: D15 Z7, engine shuts off when car slows down or comes to a stop
Does it have any codes at the moment?
Was the IACV a Honda one or aftermarket?
Old Nov 23, 2019
It's not giving any codes at the moment. The IACV is from an old d15 engine that has been reconditioned. We don't get aftermarket parts in Bangladesh, or rather expensive.
Since my original post, the idle has become rougher, and the Oil & Battery check lights come on as the engine stalls. I've seen the ABS flash on a few times as well.
I feel like I'm inside a nightmare...
Old Nov 23, 2019
Old Nov 23, 2019
Colin42's Avatar
Bad alternator?
Old Nov 23, 2019
I've been thinking about that, I will check that out.
Thanks
Old Nov 26, 2019
Thanks
Checked the alternator and the wiring yesterday. It's working fine. Changed the spark plugs for good measure. I'm still having the idle problem. However, it has changed a little. After cold cranking it, the car doesn't idle well in the morning, so I adjusted the RPM to 1.5-1.8K, cause by the time I commute back to home, the RPM gradually falls to less than 600 rpm over the whole day and the car stalls. This is my temporary fix, to keep the car running.
I only drive for about 1 hour in traffic in the morning and in the evening. Overall, the rpm falls by 1k by the end of the day. This is really weird.
Also, I've noticed the smell of engine oil from inside the car. Some times the exhaust's showing white smoke... we all know what THAT means...!
Maybe I should just save up money and get an engine...
Old Nov 28, 2019
GolNat's Avatar
Prelude Owner
Maybe do a compression test and see what kinda results you get.
Black Ninja II
Apr 21, 2018 06:33 PM
KivikinPieces
Nov 9, 2017 02:26 PM
Philip54
Oct 29, 2010 08:29 PM
JerryKay
Jun 5, 2009 03:41 PM
NoToRiOuSxPiNoY
20
Jul 23, 2003 05:14 PM
