97 Honda civic crank no spark
Old Feb 5, 2021
Sloelolk68's Avatar
Sloelolk68 is an unknown quantity at this point
I have read all of the related post I could find about my problem. I bought the car not running but had a ignition that was in pecies I fixed the key lock assembly and the.car now turns over but no spark I did the test.liggt.check slarks.plugs new o es no spark wires cap coil all new distributor also not new but one from..pic-a-part stll no spark there is power at the distributor coil but no spark when I turn it over same as old distribution what am I missing I ran the codes and p1298 came up now will that cause no spark there is power at the distributor any ideas anything
Old Feb 6, 2021
Wankenstein's Avatar
Re: 97 Honda civic crank no spark
check mechanical timing to see if the crank and cam are out of sync?
did you do a spark test on the ignition coil and ignoter(even though you replaced the distributor)?
​​​​Watch the video below in my signature.
Old Feb 6, 2021
Sloelolk68's Avatar
Yes I did check the coil and ignitor and nothing there was power at the coil but no spark so new distributors plugs wires cap rotor, I haven't looked at the timing cam and crank marks will do that first thing in the morning
19civicDX98
Feb 20, 2018 09:20 PM
civic98?
Sep 19, 2017 06:54 AM
MjCiviC97
Aug 2, 2013 08:20 AM
LilGDUB
Jun 16, 2011 01:29 PM
bmfs001
Apr 19, 2011 09:35 AM
