low compression Not sure what to do now
Old Jun 26, 2019
Deadpool11085's Avatar
Deadpool11085 is an unknown quantity at this point
So I have a 98 DX D16Y7 170k miles. So far I have put new HG, new head bolts, new rad, new thermostat and thermostat housing, the timing was done in March with new belt, tensioner, and water pump. The car runs and drives but it has low compression and it FINALLY doesn’t over heat anymore. I drove it about 6 hours to have my brother in law take it to Mexico to get a paint job and the AC fixed and I didn’t have to stop due to the over heating issue I was having previously. My biggest issue at this point is low compression. I did compression test and my psi is as follows.... #1 160, #2 140, #3 130, and #4 170. I have read way too much on what the correct PSI compression should be and I’m at a loss. It’s not smoking so I’m wondering if the rings could be fried without smoke? I’m also getting misfire in all 4 cylinders. When I drive it I hear a sound like a spray paint can rattle when I accelerate and I’m under the impression this is detonation. Can someone PLEASE give me some advice on what this might be?
Old Jun 26, 2019
Re: HELP!! Not sure what to do now
Also, when I had replaced my HG the first time I had the head resurfaced and reused the original head bolts which apparently I’m not supposed to do and used a cheap head gasket. It had started to over heat again so I put a fel pro HG and bought new head bolts the second time around. It’s not over heating now and I don’t seem to have any bubbles coming out where the rad cap is which is obviously a sign of a bad HG. Again, at this point I’m just trying to figure out my low compression and if it’s my rings even though it’s not smoking. Also, ALL my seals and gaskets have been replaced including front and rear main seals, cam shaft seals, valve cover and oil pain gaskets, spark plus seals, EVERYTHING except the valve stem seals.
Old Jun 26, 2019
Re: low compression Not sure what to do now
recheck spark plug torque
Old Jun 26, 2019
Colin42's Avatar
rattling sound could be that the exhaust manifold is cracked
Old Jun 26, 2019
what Problem would this be causing?
Exhaust manifold is good, already checked that. The rattle sounds internal.
Old Jun 26, 2019
mac25's Avatar
Dr Krieger of Modification
Did you keep track of the original valve order?
Did you de-glaze the cylinders?
If not then the valves/rings may need time to break in and deal properly.
Also hopefully you clocked the rings the right way and none of the gaps rotated over the wrist pins.
Old Jun 26, 2019
I didn’t replace piston rings or anything. I’m only wondering if that could be my issue even though it’s not smoking.
Old Jun 26, 2019
if you did not torque the spark plugs, it could lose pressure and cause misfires
Old Jun 26, 2019
Seems unlikely to cause misfire in all 4 cylinders. Regardless, it wouldn’t be causing my low compression..... you do a compression test with the spark plugs out of the engine.
Old Jun 26, 2019
true that, sorry.
Old Jun 26, 2019
true that, sorry.
No worries, I honestly was asking what that would have to do with it. I’m open to any and all information I can get at this point.
Old Jun 27, 2019
it's common for the oil rings to get stuck with carbon deposits and they will not function proper anymore to hold oil.
Old Jun 27, 2019
mac25's Avatar
Did you deck the head? If not then that gap may be losing compression. Especially with cylinders 2 and 3 showing low compression. The middle of the head is usually where it warps.
Old Jun 27, 2019
I had the head decked before I did my first HG. I didn’t do it for the second one. It only over heated once after the first HG replacement, don’t think I even drove it 100 miles. Think it would have warped again?
Old Jun 27, 2019
Colin42's Avatar
It can....
jaylo600
Apr 12, 2016 12:22 PM
shark13
17
Mar 11, 2015 03:20 PM
Dan Laz
Dec 23, 2014 08:26 PM
texas-longhorn
36
Jan 14, 2013 12:45 PM
whateg01
May 23, 2008 12:35 PM
