trouble starting...crank but won't start
Old Feb 16, 2021
Neme Sis Yaj's Avatar
Neme Sis Yaj is an unknown quantity at this point
here is what happen ....I was going to clean the throttle body before taking my car to get it smog test. I took off my intake arm to spray some Tb cleaner into the intake manifold but it turns out that I had spray the wrong can in by accident. the can I sprayed in was belt dressing instead of tb cleaner. Now my car won't start. it crank only seems like no spark. I tried spraying some starting fluid but same result. it also back fire with a little pop noise and smoke while I tried starting. what to do? I also replaced the sparkplugs and wires and Tb along with the tps after the accident occur but didn't help. I tried starting while stepping on the gas pedal down but no luck. now seems like my battery is being drained out due to all these failed attempts to starting the car. I'm open to any ideas on what to do...checked all fuses still good also. no cel code. my car is a 96 honda civic ex. couple.
Old Feb 16, 2021
Wankenstein's Avatar
Re: trouble starting...crank but won't start
recheck the spark plugs wires firing order. Backfire into the throttle body is a sign of incorrect firing order. Charge the battery for several hours to optimize cranking.
Old Feb 17, 2021
you need to mention that it is a K24 turbo swap...
Old Feb 17, 2021
BrotatoChip's Avatar
Super Moderator
I would remove the MAP sensor and clean it well, probably coated in the belt stuff.
Old Feb 17, 2021
Tes0003's Avatar
Tes0003 is an unknown quantity at this point
Stop cranking starter so much if battery is slowing down settle... Youll end up frying something else
Old Feb 17, 2021
I got it started ....thanks alot those who reply...
Old Feb 17, 2021
Bro ur advice helped alot... the wires were incorrect that's half of the problem solved...thanks alot...I guess I was rushing and over looked the wires....
Old Feb 18, 2021
if that is true, you don't have a K24. It does not use distributor, no way to mix cables there.
96 civic k24 turbo
all the body works done by me with scrap parts with help from my #1 shop HomeDepo (I'm a poor guy so it's the best I can do. PLEASE DONT HATE)
here how I look so far
Old Feb 18, 2021
Super Moderator
At this point not much surprises me. But yes it would be nearly impossible to have them mixed up unless you have a majorly hacked up harness.
Dustind903
May 1, 2018 12:46 PM
Matsal16
Jul 13, 2017 07:26 PM
fathom7411
Oct 11, 2016 05:16 AM
roushman
Engine start problems
Jun 21, 2011 08:49 AM
kcjh23
Feb 21, 2007 03:22 AM
