1993 Honda civic EX D15 wont start. A lot replaced
Rep Power: 0 1993 Honda civic EX D15 wont start. A lot replaced
Bough this car 2 Years ago with this engine already swapped and ran fine until about a month ago.
I was driving and it just turned off out of no were. took a while to start again and every time i gave it gas it would turn off. If i just let it coast without giving it gas it would but eventually turn off. I kept doing this until I got close to my house and it wouldnt turn on anymore.
Cranks but does not start. Sounds like its about too but doesnt and you can smell a little gas or some other fume not too sure.
Things replaced:
Main Relay- about a year ago
Starter- 3 months ago
Issue started then I replaced- all less than a month
Complete Distributor
Fuel Pump
Fuel Filter
Spark plugs and wires
Battery
All fuses have been checked
Was told to disconnect Cat. cause if it gets clogged it wont start. Tried it, same issue.
Cleaned Throttle body a bit
Was told MAP sensor can cause this problem but dont want to keep dropping money on something that wont work. Any Info on this?
No check engine light. I dont race or beat this car up or anything like that.
Also there is a long clicking noise coming from the driver side somewhere behind the steering wheel or from engine bay when i switch the ignition on before i actually crank it. Last about 3 seconds. always did this though.
My new daily takes about $150 a week on gas so i need this gas saver up and going again lol
Things replaced:
Fuel Pump
Fuel Filter
Battery
Re: 1993 Honda civic EX D15 wont start. A lot replaced
Have you tried spraying starting fluid into the throttle body/intake?
OEM or aftermarket? Did new distributor cap come with the new distributor?
Brand? Did you gap the plugs to spec? Are the spark plug wires in the correct firing order?
Pull a used one from junkyard
Was the crank sensor near crankshaft ever replaced?
Also, check both the ignition timing (distributor) and mechanical timing (timing belt)... the timing belt may have skipped a tooth/teeth which can also cause a crank with no start issue. I would start here first because there's no cost to do so.
Rep Power: 0 Re: 1993 Honda civic EX D15 wont start. A lot replaced
Sorry, i haven't had time to mess with the civic lately but i did try some stuff and nothing still.
I tried starting it with the gas pedal all the way down.
It has a new distributor from autozone. its a complete unity so new cap and rotor as well.
i got Duralast wires and not to sure on the spark plugs. i used the same brand when i did the turn up the first time as well and they work fine for me.
I replaced the MAP sensor and nothing.
i have yet to check the timing but i did check the belt and it seems fine to me.
Anything else you guys can think of?
Things replaced:
Does it have spark?
