99 civic crank no start in the morning
My 99 civic is consistently failing to start in the morning. I live on the coast so it could be humidity related or cold. I have replaced the ignition coil and control module with no change. There is no spark at all four plugs when it won't start. There is voltage getting to the coil. The distributor cap is dry but there is a bit of corrosion on the contact points. I have ordered a replacement cap just in case. The plug wires look fine and the spark plugs look good. Ideas??
Re: 99 civic crank no start in the morning
Did you use a Honda oem (TEC or Hitachi) coil and control module? Those a cheap aftermarket replacement coils sold online are a no good.
You checkada relay, paisan?
Iffa you car has a manual transmission maybe the clutch safety (interlock) switch is a broken or going bad eh?
Here's a you diagram: https://static.cargurus.com/images/s...-1600x1200.gif
honvic
30
May 10, 2019 04:35 PM
kwolves21
Jul 16, 2016 09:27 PM
Peskie
Apr 10, 2013 08:32 PM
Rawmikey
15
Jun 7, 2012 06:26 PM
bangbangexpress
Apr 30, 2011 11:36 PM
