99 Civic EX need opinions
Old Apr 27, 2011
bangbangexpress's Avatar
bangbangexpress is an unknown quantity at this point
Last week my wife's 99 civic would crank all day but not fire. So I started with fuel replaced fuel filter and checked fuel pressure all good. Moved on to spark and found that I had none. (Also replaced the Main Relay)
Ended up replacing Cap, Rotor, and Ignition Coil. Car fired right up (after fuel lines refilled) and ran great. Problem solved or so we thought.
Its been 5 days now and this morning wife went to the car to go to work and now has the same problem. I took Cap rotor and ignition coil out and inspected them they all still look brand new like they should. Put it back together stumped as to what the issue could be. Before I went in the house to call someone decided for ***** to see if it would start and low and behold damn thing fired right up no problem and ran great around the block.
Now my issue the wife is 8 months pregnant and I do not want here getting stuck somewhere and shes afraid to drive my F150. Anyone have a clue why taking it apart and putting it back together seemed to work? And what can I do to make sure it dose not happen again?
Old Apr 29, 2011
lazlong's Avatar
Re: 99 Civic EX need opinions
Is it getting voltage to the distributor? Possible short?
Old Apr 30, 2011
Dizz's Avatar
Dizz is an unknown quantity at this point
sounds like a tough one!When it was dead the 2nd time,did you check the plugs for a nice blue spark?
Regards,Dizz
Old Apr 30, 2011
MelJ's Avatar
Trance Addict
I'd start with what was already mentioned. You replaced just about everything in the ignition system. What about the plugs? I would at least examine them like Dizz said. Note their condition and see if they're fouled.
McD
Apr 29, 2015 03:50 PM
inarschenk
South
Apr 18, 2015 04:29 PM
McD
Apr 16, 2015 10:46 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
GabberHead
Nov 1, 2001 02:28 PM
