New to me 98 Civic Cx. Crank wont Run.
Old Jun 3, 2020
Stephanie B's Avatar
Stephanie B is an unknown quantity at this point
My car drove 30 miles when purchased. It did quit running on the highway. I restarted it and drove home. It has a new fuel filter. The ignition recall has been done already. Could it be the fuel relay ?
Old Jun 3, 2020
Colin42's Avatar
Re: New to me 98 Civic Cx. Crank wont Run.
Might be the man relay, might be lack of spark. You need to check which of those you are missing when trying to start the car
Old Jun 7, 2020
Thank you. The man that replaced the fuel filter told me that there is next to none, exhaust pressure coming out of the muffler. Could the catalytic converter be bad or clogged?
Old Jun 7, 2020
Colin42's Avatar
Certainly a possibility, you can loosen/remove the bolts that hold the exhaust manifold to the cylinder head and try to start it
Old Jun 9, 2020
Thanks again. My friend seems to think that would involve a gasket replacement. He doesn't want to do that. I'll hire someone.😜
Old Jun 9, 2020
FRSam's Avatar
Click Here
It doesn’t.
Edit: My dumb *** read head gasket replacement. Ignore me. You could probably still get away with not replacing the exhaust gasket though.
Old Jun 9, 2020
Colin42's Avatar
Exhaust manifold gasket is reusable steel
jrlopez808
Sep 15, 2012 03:39 PM
kookoo
May 16, 2010 05:16 PM
jaywelch61
Apr 17, 2010 04:13 AM
24civic
May 25, 2009 12:02 AM
red98ex
15
Mar 10, 2009 12:32 PM
