98 civic ex just dies
Old May 23, 2009
24civic's Avatar
24civic is an unknown quantity at this point
I have a civic that i bought for my daughter and will just die replaced everything under distributer cap that you could buy from oriellys and put in new fuel pump it will just die no warning lights no alarms on the computer at the shop. If you have any ideals please let me know.
Old May 23, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: 98 civic ex just dies
so it starts up fine but dies when u drive it?
Old May 24, 2009
24civic's Avatar
when it dies it takes a few minutes than fires up and runs fine
Old May 24, 2009
lorolia's Avatar
lorolia is an unknown quantity at this point
it could be the main relay that has a crack on the soldering and it has to be re soldered again
also it could be good to check fuel pump relay
Old May 24, 2009
24civic's Avatar
are they in fuse box under they hood
Old May 24, 2009
daragez's Avatar
daragez is an unknown quantity at this point
check the relay!...yeah under the hood!....
Old May 25, 2009
24civic's Avatar
relay is fine the ignition switch is the problem i believe now the dash lights wont come on when you try to start the car and when it dies the only way to roll down the windows is when the key is turning over the engine
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
silvervtec01
Nov 4, 2001 06:56 PM
