98 not starting
Old Apr 30, 2010
kookoo's Avatar
kookoo is an unknown quantity at this point
Exclamation 98 not starting
ive replaced most of the ignition tune up components and still no start. ifigure afuel delivery issue. need to know how to check fuel pressure. im a modestly skilled " do it yourselfer" so please walk me through any suggestions. is that the fuel filter on the firewall? how involved is replacing that?
Old May 2, 2010
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Re: 98 not starting
My 98 did the same number awhile back, it just wouldn't start. I replaced the fuel filter, checked spark and everything over and it turned out to be a connector (the one on the right side of the engine bay by the powersteering reservoir) that wasn't connected all the way. I snapped it together and she started right up.
Hope that helped, for what it's worth
Yes, the fuel filter is that acorn shaped thing by the firewall that has the line leading to the fuel rail. Pretty simple to change it out. Just gotta remember the bottom nut is backwards cause it's facing downward.
Old May 3, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: 98 not starting
Need more info: what does it do.. crank but not start? Does it click at you when your trying to start it.
Check your fuel pump, put the key in the ignition and put it to II and listen to the fuel pump, it should engage.
Check to see if you have spark at the spark plugs.
Old May 14, 2010
fredogrimey's Avatar
fredogrimey is an unknown quantity at this point
Re: 98 not starting
My 99 civic didnt start and it ended up being the switch on the clutch pedal.....
Old May 16, 2010
JonnyT_373's Avatar
JonnyT_373 is an unknown quantity at this point
Re: 98 not starting
Does the engine try and turn over?
When you switch it to the "On" position (but not starting it) do you hear the fuel pumps turn on and then the main relay "click"?
Have you check the spark at the:
Plugs?
Distributor?
Ignition coil?
The more info you post the better people can help you. There are a lot of components that go into starting a car mechanical and electrical.
Old May 16, 2010
kookoo's Avatar
Re: 98 not starting
checked coil o.k. gonna do compression test next. tough because i dont know cars entire history but thanx for all the response my time is limited to play around with it ; but ill eventually figure out just whats going on.
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
