D16Y8 hits revlimiter at 5,000 rpm
Old Jan 29, 2020
Tyler Brown's Avatar
Tyler Brown is an unknown quantity at this point
I have a 1998 honda civic ex 5 speed with a d16y8. while I am driving the engine will hit the limiter at only 5,000 rpm. I have two engine codes a vtec and a evap emissions code. I changed the head gasket about 2,500 miles ago. the revving problem started about 500 miles ago. I have two ideas. one being the engine codes have caused the car to go into a limp mode. two the computer thinks the transmission is in neutral and is keeping it from revving all the way. The car runs perfect until it falls on its face at the 5000 rpm limiter. no backfire, no surging, no loss of power. its just like the 7000 rpm limiter. I cleaned the vvt solenoid and valve body thingy with no change. I will later test the solenoid and post the results. Any ideas on diagnosing the problem or previous experience with it?
Old Jan 29, 2020
Re: D16Y8 hits revlimiter at 5,000 rpm
Vtec solenoid dose click when hooked to 12v. guess I should have tested it while it was off oh well.
Old Jan 29, 2020
Colin42's Avatar
Is your oil full?
Old Jan 29, 2020
Originally Posted by Colin42
Is your oil full?
yes it is full. I check it regularly.
Old Jan 30, 2020
FRSam's Avatar
Click Here
It could be a fueling issue. Is it bouncing like it would a rev limiter or is it holding like it would be cruising, and just not exceeding 5k? I'd check the fuel filter to see if it's clogged. The EVAP code could indicate that it's running lean.
Old Jan 30, 2020
it's bouncing just like a revlimiter. I dont think its a fuleing issue but not a bad idea to check the filter
Levi likes si
Apr 29, 2013 09:09 PM
cwo715
16
Aug 20, 2010 09:26 PM
Hondan
Jun 11, 2009 12:46 AM
dbsk8r1212
15
Nov 8, 2007 11:04 PM
return_2020
Aug 22, 2005 10:22 AM
