how much better?
Old Nov 7, 2007
dbsk8r1212's Avatar
dbsk8r1212 will become famous soon enough
how much better?
how much better is an h22 engine than a d16y8?
like how much more hp does it have and how much better is the acceleration nd top speeds?
just a stock h22 and a stock d16y8
Old Nov 7, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: how much better?
H22
Bore × Stroke: 87.0 × 90.70 mm
Displacement: 2157 cc (132 cu. in.)
Valve Configuration: DOHC, 16 valves, VTEC
Type: In-line 4 cylinder, aluminum block and head
Compression ratio: 10.0:1 (North America); 10.6–11.0:1 (Japan)
Max power: 190PS/187hp (CD6 Accord); 200PS (BB1/4/6 Prelude SiR's); 220PS (Euro-R & Prelude Type-S) ;A7 220bhp DIN (Type-R)(142–164 kW)
Max torque: 156–167 ft·lbf (207–217 Nm)
Redline: 7600 rpm
Rev Cut: 7800 rpm
Engine Control System: Honda Systems PGM-FI with port fuel injection
Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift
D16Y8
Displacement : 1590 cm³
Bore and Stroke : 75 mm X 90 mm
Compression : 9.6:1 Piston Code:P2P
D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590
126 hp@5900 rpm 108tq@4800 rpm
Head Code : P2P
VTEC crossover: 5300 rpm
Redline 7200 rpm
Old Nov 7, 2007
dbsk8r1212's Avatar
well do you have any way of finding like the 0-60 times for both of them stock?
Old Nov 7, 2007
FGCOUPE's Avatar
check youtube out?
or maybe someone here knows?
Old Nov 7, 2007
dbsk8r1212's Avatar
yea well does anyone know?
Old Nov 7, 2007
FGCOUPE's Avatar
my choice...H22 but i dont know either motor either?
but reason chose the H22:
- 2.0L DOHC VTEC
- Compression ratio is higher (try and get a JDM)
- Higher HP
- Bigger TQ then the D16Y8 engine
Old Nov 7, 2007
dbsk8r1212's Avatar
well i just looked up h22 vs d16y8 on google videos and i saw one where a prelude with an h22 won then i saw another with a different prelude but same engine lose to the d16y8.
so i can't really tell.
ok ANOTHER ?
what do you think of a d16y8 v.s. about a 2000 dodge neon bone stock
if the civic has an intake,headers,fitpipe, exhaust system, and a performance chip
Old Nov 7, 2007
FGCOUPE's Avatar
ok...i aint even goin here! haha
Old Nov 7, 2007
dbsk8r1212's Avatar
yea i like the hp and the torque.
but i'm not willin to pay a whole lot more for a swap right now.
i think i'm just gonna get a swap when i get ready for my next civic.
Old Nov 7, 2007
dbsk8r1212's Avatar
wait what do you mean you aint goin there lol
who do you think would win?
because well the drivers been beat by alot of guys i know
one of them even raced in his grandpa's 5 speed nissan pickup lol
he won and he was talkin on the phone while racin.
so do you think a civic would have any problem?
Old Nov 8, 2007
Syke Fu's Avatar
Syke Fu will become famous soon enough
I assume the guy in the civic lost if i follow you correctly...
Either:
A) He can't drive
B) Something is wrong with the car mechanicaly
C) The other car had a little something special under the hood (perhaps a better driver??
Old Nov 8, 2007
TRIZ's Avatar
If you wanted to swap it and it worked, I'd rather have a H than a D.
A prelude type S would be sick *drool*
Old Nov 8, 2007
lemac's Avatar
lemac will become famous soon enough
Originally Posted by FGCOUPE
H22
Redline: 7600 rpm
Rev Cut: 7800 rpm
D16Y8
Head Code : P2P
Redline 7200 rpm
Well, I'll say thanks for the info
Old Nov 8, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
H22 worth more than D16 D16 worth nothin ...maybe $100 ?
D16 beat H22 ? yea .. D16 can do lower tha 11sec in 1/4 mile and how many time did u see that happen?
good lucky on choosin
Old Nov 8, 2007
FGCOUPE's Avatar
Either:
A) He can't drive
Old Nov 8, 2007
DsevenEm2's Avatar
This is Myspace
stop street racing u douche.. its not safe..this isnt a movie.
