Effect of increasing rpm from 6800 to 7200
Old Jun 9, 2009
Hondan's Avatar
Hondan should not be trusted
Engine: D17A sohc vtec
What is the effect of increasing the rpm from 6800 to 7200 or even 8000?
Old Jun 9, 2009
Zzyzx's Avatar
Autocross Junky
Re: Effect of increasing rpm from 6800 to 7200
other then blowing the engine?
Anyway, you probably should refresh your understanding on engines torque & RPM's...
This is a good start.
Ultimately, there's 0 reason to increase a cars rev limiter unless you've significantly altered the cars torque curve.
Old Jun 9, 2009
Hondan's Avatar
Thank you. what about increasing the km/h from 180 to 240?
Old Jun 9, 2009
Zzyzx's Avatar
Autocross Junky
km/h = Kilometers per hour.
http://en.wikipedia.org/wiki/Kilometres_per_hour
Going from 180 to 240 means that you would have increased your velocity by 60 km/h.
Old Jun 9, 2009
Jp7's Avatar
Jp7
Jp7 is an unknown quantity at this point
Stretched rod bolts, increased bearing wear, rod damage. All more likely.
Old Jun 9, 2009
Hondan's Avatar
I just want to increase the top speed.
The computer come in at 180 km/h.
What is the effect of changing the ecu to delimit at 240 kmh
Old Jun 9, 2009
in most cases, esp with a civic, hp drops off after the car's original redline. so you wont get any performance and end up destroying the engine in the process. theres no reason why you need to increase top speed over 65mph unless youre moving to germany. these cars already go at least 100mph if not faster, which is more than enough to land you in jail with a torn up license.
Old Jun 10, 2009
unTuned's Avatar
this has to be one of the most retarded threads ever.
Old Jun 10, 2009
ADMCivic's Avatar
ADMCivic is an unknown quantity at this point
No need to ever go faster than 180km/h and your only gonna do damage if u rev it past the limiter.
Old Jun 10, 2009
Zzyzx's Avatar
Autocross Junky
Get "taller" tires. You'll loose acceleration, but you'll increase your top speed.
The problem your going to run in to is that you are simply going to run out of torque. as in the car simply doesn't have the power to over come drag at higher speeds. Raising the rev limiter isnt going to help, because you haven't altered the cars torque curve.
As in, with out modifying the engine a good amount, you'll never get your civic to 240kmh (~150mph)
Old Jun 10, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
From you first post i assume you have a civic ex is it manual or auto? Why do u need to increase the rev, a stock civic ex can go over 180 km (112 mph) If you want to go even faster get an lx manual tranny, which has longer gears=higher top speed
Old Jun 10, 2009
Jp7's Avatar
Jp7
no boost = no chance
Old Jun 10, 2009
unTuned's Avatar
i try my best not to criticise any threads...but i cant handle this one. its hurting my eyes. once again...what a retarded thread.
Old Jun 11, 2009
Hondan's Avatar
I have 215/35/R18
Singapore market - 7 gen civic goes up to 240kmh.
Old Jun 11, 2009
Hondan's Avatar
Japanese - JDM Civic RS manual shift.
SimpleUser
Apr 24, 2021 02:54 AM
scootz_7
Aug 25, 2015 12:31 PM
GritzNGravy
Aug 19, 2015 03:03 AM
Bonnabell
Aug 14, 2015 04:15 PM
brennov8
Jul 13, 2015 12:57 PM
