2000 civic radiator fan
Old Aug 14, 2020
ltfan1833's Avatar
ltfan1833 is an unknown quantity at this point
Exclamation 2000 civic radiator fan
my radiator fan is not turning on. i have replaced the thermosensor, and when i stick a paperslip in to test, it turns on. did i buy a faulty sensor? ive overheated my car multiple times trying to fix this so any help would be great.
Old Aug 14, 2020
Wankenstein's Avatar
Re: 2000 civic radiator fan
You engine's problem is most likely much bigger than the rad fan not switching on. Several overheats probably has lead to a blown head gasket.
If there's exhaust emissions in the coolant system causing bubbles the ECT may not be reading correctly to engage the radiator fan. Do a block test on it to rule out unwanted emissions in the coolant system.
Old Aug 15, 2020
Got head gasket problems?
What do you see that leads you to believe the engine is overheating?
Temp gauge problems? Gauge isn't accurate?
See what the PCM believes the actual engine coolant temp is, as shown on a real scanner data list.
Does that number tend to agree with the needle position on your temp gauge?
The dash gauge and the engine computer each have their own coolant temp sensor.
The radiator fan uses yet another.
What temp is your new fan switch rated for?
Got flow problems? The engine could overheat and the fan switch would never know it, if liquid isn't circulating correctly.
Cooling system is full of 50/50? Cooling system holds pressure?
rebel1
Apr 8, 2012 11:24 AM
wsuguy28
Apr 30, 2009 03:14 PM
supafreak101
Sep 4, 2005 08:02 PM
HondaLuver
Engine Swaps
Aug 3, 2005 11:40 PM
iamboo
Engine Swaps
Apr 30, 2004 06:05 PM
