- metallic rattling noise at cruising speeds and at some acceleration points
- Re: Leaking oil
- Motor mount bolt
- A hose
- BAD vibration between 28-40 mph
- Need SRS help 2015 civic EX
- Noise from right front tire
- unknown leak
- Car wouldn't start--starter replaced--now wiring burnt out
- Honda civic 1.8L 2006
- Turbo 07 civic si died and now won’t crank
- 2012 civic ex vibarting
- Loud vibrations at low RPM
- 2006 civic. Strong burning plastic smell and rattle
- Roll Bounce!
- Best aftermarket A/C Evaporator Core for 2006 Civic LX
- 2006 ac diagram and info needed
- 07 civic vti fans not working
- AC not working on 2010 Honda Civic LX-S
- ac field coil burned up and no power to new one...
- Compressor Clutch Shims
- key battery replaced still wont start
- where is fuel pump located?
- Civic 2006 another ac issues
- 2012 Heater control valve location
- Multiple CEL codes, help would be appreciated
- 2009 Honda Civic Won’t Start All of a Sudden
- Strange A/C problems...07 Civic
- Need help
- Bad synchro?
- Belt tensioner bolt stripped 2007 Civic lx
- 2013 Accelerating on its own!? (Manual transmission)
- 2010 Air Mode Control Motor Stuck
- Standard 2012 civic, RPM give out around 3000
- 2006 Civic Si Couple - Yellow Fluid Leak
- Driveshaft Replacement
- Can someone please help me with my civic
- Mystery oil leak
- What common mechanical problems to look for on a potential purchase?
- Speedometer won’t work, obd2 won’t connect to car
- Starter noise
- 07 civic lx air conditioning
- Zero Compression Cylinder 2
- 2011 Civic Vibration
- "How to" needed for replacing the water pump
- 2009 Civic LX - a/c issues
- Car is dying low idle at stops. 2009 civicI am fixing to check map
- Strange grinding noise on cold startup- 2007 Civic Si
- Undercarriage plastic cover damaged
- 2006 Civic DX - Transmission Speed Sensor
- 2012 gremlins
- replacing torque strut
- 2008 Civic LX (2 doors) - A/C works intermitently
- Parasitic drain? Relay?
- Check engine light on 2014 Civic
- Control arm issue
- 2014 Coupe Gas Cap Warning
- Cost to Replace Side Engine Mount
- Jumpstart 2006 Honda Civic with bad starter
- Rear lights all out 12 Civic Couple EX-L
- 2014 No Heat and No AC
- Cleaning Oil Soaked Engine Bay
- Minor issues with my civic hybrid.
- 2010 LX W/ SI Stock Radio really low sound
- what nuts ?? (08 civic)
- Help - CVT fluid change, opened check plug first and didn't overflow over 4 bottles
- What issues do 06-08 Si's have?
- 2008 Civic EX Engine Noise?
- 2007 1.8l auto year long starting problems
- Multiple misfire
- 2012 Passenger Side Airbag Off
- 2008 IMA knocking sound below 2200rpm
- 2008 civic R18 spun bearing
- Honda Civic clunk from brakes.. Please help.
- Car is vibrating
- Car won't start, Starter issue? Bad battery?
- 2010 Civic Coupe broken shield
- Steering Column Loose
- 2008 Civic LX Sedan not starting
- Winter Battery Issue
- 2007 Civic P0455/P2646
- 2016 Civic LX Noises
- 2006 Civic EX Coupe P0128 Code
- 4 months old brakes, shaking steering wheel and brake pedal when braking
- 2014 Civic - Flapping/Loose Piece Under Car
- 09 civic delay in starting
- Car stopped moving, what is this part?
- Engine light + Shake
- High Fuel Consumption
- CANT SHIFT INTO 3RD. D light blinking
- Replacing sunroof motor!!
- '09 Civic SI Fried ECU?
- Bypass AC Compressor on 2008 Honda Civic LX
- 2012 Civic fob won't work on driver doors.
- Civic 2013 - Check Emission System
- Charging System Nonstop Problem
- Which oil specification is the best quality?
- Alarm keep sounding
- 2010 honda civic internal fan loud
- 2012 Civic Chatter/Judder
- 2010 Civic engine temp gauge flipped upside down! (No joke)
- Occasional slight "buck" / "miss"
- 2009 Civic Ignition Issue
- Did I really need a new battery
- 2012 Honda Civic Radio shuts off and Headlights Dim
- 09 Brand New Battery Won't Start
- 2014 EXL Sedan vibration
- What hose is this leaking?
- Knocking sound (tok)
- '07 Civic Si clutch/tranny squeal/whine noise
- Do I need to Replace my Car Battery?
- Leaking water on passenger side
- Fixed control arm and axle but something else is still bent
- 08 Civic won't start
- Maintenance Minder Blunder
- What is this part called help!
- 06 EX Coupe Manual Instrument Cluster FLICKERING
- Defrost stuck on
- 2012 Civic Intermittent engine rattle, LX sedan R18 AT
- 2007 civic heater issues
- Way to much oil
- Fuel Lines in 2007 Civic
- 2010 windshield washer question
- zipper sound when trying to start honda civic 2206
- white smoke from exhaust
- Battery light comes on at idle, I have tried EVERYTHING
- Serpentine belt/Crankshaft sensor
- Dead Battery, Jumped, Then Air Bag Light On
- 2007 Civic Fuel System Rich
- ECH problem!!!b1168;b1169
- Steering wheel lock
- Help! Coil pack wires eaten by critter
- Gurgling Noise On Cold Start and Low RPM
- 2006 Civic Hybrid - P010A
- 2015 Civic EX-L Radiator tank
- 2006 Honda Civic Ex
- 2008 Civic LX Shaking/Vibrating Question?
- Maintaining my 2008 Civic LX
- 2006 Civic EX Starting Problem
- can refilled AC 08 civic stays @ low pressure
- 2007 Civic Coolant issues
- 2008 Civic S, ventilated engine block
- 2010 Honda Civic lx gas mileage problem
- Turn signal lever won't latch turning right
- To stroke or not to stroke? (K24a2)
- 2007 Civic EX Coupe has a squeal while driving.
- Civic 2006 temperature fluctuating
- Popping type noise coming from Suspension?
- Feeling a "clunk" when shifting
- Accessory Belt Tensioner Loose
- 06honda Ac
- 2007 SI clutch replacement
- A/C Problems, PLEASE HELP!! cant find solution
- Temp. sensor maxed out and check engine
- 07 GX: Check engine light / Coils keep blowing
- 2010 civic AC issues
- A/C Short
- tires on my 1998 civic ex 15's?
- Civic 2012 LX
- What is this wire? I just bought this used 07 Civic Hybrid
- AC issues. Please help!
- 2008 Dx with a persistent poor idle after starter change
- Civic 8th gen 2.2 icdti
- Not the Usual A/C Thread
- Problem starting 2015 Civic lx
- 08 A/C and Electrical issue
- 2006 Honda Civic Fuel Pump? Sluggish in the morning
- EGR tube location
- Key fob shell?
- 2008 Civic Hybrid Air Conditioning
- 08 Hybrid Rattling Noise when Accelerating or Coasting
- 07 Civic With Digital Speedo
- 06 civic lx won't take freon
- Oil for Civic / Filter
- 07 EX AC Malfunctioning
- 06 will not start?
- Civic 2009 Problème
- ATF question
- 2009 Honda Civic Cruise Control
- 2007 Honda Civic AC issue
- Broken spring(s) in driver's seat-- how to fix?
- 2013 civic hood latch
- 2006 civic a lot of problems
- A/C blows weakly after 5 min
- Anti theft when car stalls
- DRL help!
- Trunk Latch Mechanism
- Clicking once per wheel roation.
- 09 civic coupe ex 1.8l
- replacement 18 engine question
- Trunk Latch Diagram/Advice.
- 2011 HondaCivic horrific screeching sound.
- Alternative to Honda ATF
- Grinding when accelerating
- Vibration @ 50 mph
- 2007 Honda Civic LX Brake Issue
- How to disable TPMS light on dash 2010 Civic ?
- Easy question: 2015 Civic Ex: Sensor on Transmission
- 2009 civic losing torque & engine horse power in hot weather.
- 2008 Civic pre-purchase what to look for?
- 2006 civic si trunk issues
- 2007 Driver door lock doesn't respond to fob/panel button
- HELP! Water leaking inside.
- 2008 Civic EX idle and window problem
- 09 Hybrid Carpet Replacement
- Civic EX driver window rolling up then rolls halfway
- 2006 Civic Ignition Lock cylinder replacement issues
- 2013 civic EX: A/C compressor clicking on and off rapidly
- 2006 Civic EX hesitates/stalls when accelerating from stop
- Remanufactured or new AC compressor and clutch?
- 2005 Civic front end repair
- 2008 civic makes rattling noise in rear
- Blower motor
- 2006 Honda starts, bogs down, and dies...
- 2007 Honda Civic Debugging - Clicking noise, won't start
- 2006 Civic electrical issues
- quick jerk
- [HondaCivic07] Heavy vibrating engine noises in park, reverse and releasing gas pedal
- Clutch pad issue
- Average age of bearings?
- Intermittent Parasitic Battery Drain
- 8th & 9th Gen Prop Rod Holder Clip
- 2008 Honda Civic OIL OVERFILLED/TPMS HELP!
- 2007 civic hybrid motor mounts continually breaking
- P2646 issues for 2004 Honda Civic EX
- Grinding noise when starting car
- Cooling Fan Issue
- '08 Civic won't start -- possible alarm issue
- Car not moving even in gear
- Electric window question
- Noise just before stopping hard
- 98 civic dx 5 speed will crank but not start!!
- Engine vibration 1500-1700rpm
- p0128 code question
- 2012 Civic Water boiling noise ehind dashboard
- 2009 civic ex start issue
- Hard Starting
- Best place to buy a replacement driver side mirror
- Ignition coil hairline crack. Replace?
- Bite the Bullet or Let it Go
- 06 Civic LX sputtering and blinking engine light
- 2006 Civic EX Drive/Serpentine Belt Replacement?
- 08 Civic coupe and sedan fenders the same?
- Honda Civic 06 ex Bypass AC pulley
- 2007 Civic AC Delete belt size?
- Car won't start 5 times in one week!!
- 07 si need belt size to bypass locked up ac
- 2009 Civic LX A/C Issues
- 2008 Civic LX Engine Whine Sound, 102,000
- "passenger airbag"
