07 si need belt size to bypass locked up ac
Old Jan 22, 2017
8thgenocide's Avatar
8thgenocide is an unknown quantity at this point
i have a 2007 civic si,my ac compressor locked up, im going to fix it but for the time being i want to leave the compressor on and find a shorter belt to by pass it.. has anyone done this and can tell me what size belt i need to bypass the compressor? thank you
Old Jan 22, 2017
Re: locked up ac compressor
Search this forum, I'm thinking someone posted about this same situation with a belt number or length to use....but I can't remember what year the car was.
Did the compressor lock up or just the pulley? If just the pulley, you can buy it separately through Honda.
Old Jan 23, 2017
I'm not sure, is there a way to tell if it's the pully or the compressor
Old Jan 23, 2017
Re: 07 si need belt size to bypass locked up ac
The pulley freewheels at all times, its bearing it usually the first to go. It could have been making rattle noises for a long time before it spits ball bearings out and locks up. The clutch plate engages against the spinning pulley to drive the compressor.
The outermost plate (clutch plate) is attached to the compressor shaft, it should be able to spin by hand (assuming the bad pulley isn't pushed against it)..you may need to remove the belt to find out more.
Old Jan 23, 2017
The belt got destroyed from the pully not spinning
Frazzleddad
Jan 24, 2017 06:57 PM
