07 civic lx air conditioning
I recently bought an 07 civic lx coupe, when I first start the car the air comes out the vents very good but after a few minutes it stops. I can still feel the cold air but it isn’t coming from the vents, it does the same thing if I have the heat on.
Re: 07 civic lx air conditioning
Too vague. Need to Elaborate. More Details.
Do you mean the blower fan motor quits running?
That is where most of it is coming from, some is coming from the vents as well. But when I try to make it come from the vents nothing happens. I can turn the car off and let it set for an hour or so and it will blow out of the vents again,
Does it work normally at first, you can control where the air comes out ?
When it fails, do The controls still show the vent button illuminated?
Do a search to find the procedure for HVAC panel self diagnosis, see if it gives any fault codes.....
Could be a bad servo, could be a bad control panel....might be wiring....need to so some troubleshooting
UPDATE...... I found the video for the ac diagnostic, I ran the test but had no codes show up, but the air worked the while ride home from work. I switched the vent from head to feet and then to defrost and they all worked.
maxsimity
Oct 24, 2017 09:42 AM
fletch71
Aug 18, 2005 11:36 AM
Steve4444
Jan 11, 2004 11:45 AM
