Clicking once per wheel roation.
Old May 15, 2017
chrisp's Avatar
chrisp is an unknown quantity at this point
There is a noise coming from the front passenger wheel of my 2010 Civic. It happens once per rotation when driving and can be duplicated by rotating back and forth when jacked up:
What could cause this?
Old May 15, 2017
mac25's Avatar
Dr Krieger of Modification
Re: Clicking once per wheel roation.
It sounds light and tiny not lick it is coming from the transmission or cv joint, almost like a heat shield or the brake rotor shield.
Old May 15, 2017
Pitch or tone sounds like it might be that of the backing plate....
bent, too close to rotor?
Rock stuck?
Old May 16, 2017
Wankenstein's Avatar
I could be wrong but, it seems that he (OP) is not using much effort to move the rotor back and forth. Seems like there should be more resistance...isn't the driver's side front the axle that is powered?
Old May 16, 2017
chrisp's Avatar
Rock stuck?
That's exactly what it was. Good ear! And thank you! I fixed it last night. Saved me a foolish trip to the mechanic.
Old May 16, 2017
chrisp's Avatar
By "that" I meant the bent plate, not a rock.
Old May 16, 2017
A differential doesn't work quite that way.
