Re: Leaking oil
Old Feb 22, 2022
Civic20854's Avatar
Civic20854 is an unknown quantity at this point
Re: Leaking oil
I also noted engine oil leaking at the bottom on the transmission side in my 2012 Civic. It was first noted 2 months ago with the LED screen showing engine oil level was low. After adding a quart of oil and driving for ~2 months, the low oil level warning showed up again recently. No oil leaks to the floor where the car is used to be parked. I checked the underneath of the engine and noted the oil tank surface is completely dry (no leaking around the drain plug) while the parts on the transmission side are pretty wet as shown in the red circle of the attached picture. No other problems noted. Could any one help give suggestions on troubleshooting? Thanks.
Engine oil leaks to the parts indicated in the red circle.
Old Feb 22, 2022
Re: Leaking oil
cleanup engine, drive some and pinpoint where it is leaking from
Old Feb 22, 2022
Civic20854's Avatar
Re: Leaking oil
Thank you Sdaidoji so much for your quick response. Any suggestions/tips on the appropriate way to clean up the engine? Thanks.
Old Feb 23, 2022
BrotatoChip's Avatar
Super Moderator
Re: Leaking oil
Brake cleaner or any sort of parts degreaser should work. My guess is the rear main seal from the looks of it.
Old Mar 5, 2022
Civic20854's Avatar
Re: Leaking oil
Hi sdaidoji, H
Red circle and arrow indicate leaked oil.
ope all's well with you. Today I replaced the spark plugs because I noted the car hesitate occasionally when accelerating. All 4 spark plugs appeared normally worn out though I'm not so sure (dry, normal color, no oil or debris, clean cylinders). However, I noted leaked oil on the engine outside surface near one spark coil pack (red circle) and between the engine valve cover and the engine body (indicated by red arrow). See the picture attached. Do you think all the leak I described now and earlier is most likely related to the engine valve cover gasket, which should be replaced? Thank you.
Old Mar 6, 2022
Colin42's Avatar
Re: Leaking oil
Looks like valve cover gasket to me
Old Mar 6, 2022
Civic20854's Avatar
Re: Leaking oil
Thanks a lot. Will change the gasket.
Geldingmakr
Dec 27, 2019 11:43 AM
5hamers
Feb 21, 2017 07:14 AM
Carnivorous18
15
Jun 6, 2011 07:53 PM
TiggerDX
Nov 18, 2010 02:00 AM
