Honda civic 1.8L 2006
Old Jun 18, 2019
Lhon Lopez's Avatar
Lhon Lopez is an unknown quantity at this point
I remove the throttle body and clean it when i put it back the idle bad if you press the accelerator and release it will go down but it will bounce up and slowly goes down what the problem thank you guys
Old Jun 19, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Honda civic 1.8L 2006
-remove ecu fuse
-wait 10min
-unplug all electrical connections to the throttle body
-make sure you hear a click when you plug them back in
-replace ecu fuse
-start car
-do nothing until the throttle resets itself (should take about 2 minutes)
If it continues to have issues remove the throttle body again and make sure the gasket is fully sealed and isn't causing a vacuum leak.
Old Jun 19, 2019
Lhon Lopez's Avatar
I canno find the ecu fuse can u send me where the location thank you
Old Jun 21, 2019
mac25's Avatar
Im not sure where it is for that generation. It was listed on the back of the under hood fuse box, in the 7th gen, try looking there.
You can also pull the battery cable, but then you'll need to reset your radio code.
Cynthia Garcia
Electrical
May 28, 2019 02:17 PM
speedy25
Electronics
Apr 6, 2011 10:35 PM
01civicriderex
Dec 1, 2006 03:27 PM
Buds302
Nov 24, 2006 08:41 AM
magic_wizard
Jul 5, 2006 01:41 PM
