Multiple misfire
Old Mar 3, 2018
Reimer's Avatar
Reimer is an unknown quantity at this point
Multiple misfire
Hi, I am new to this Forum and the Honda manufactured vehicles. I purchased a 2010 Civic Coupe with a 1.8L (120K kms). Was told at time of purchase that it had a misfire. Codes came up for each of the four cylinders and the one for multiple misfire. Sparks plugs have been changed. Checked Coils and all look to be good and sending spark. EGR valve looks to be clean and did not send a code. The misfire shows up when you are stopped at a light, increase the RPM and it goes away. Also, misfire occurs when you reach 80 kmh (50 mph), goes away when you increase speed or lower speed. No problem durimg imcreased acceleration. Any ideas???
Old Mar 3, 2018
Re: Multiple misfire
You ignored the warning signs! Bad move....
Correct plugs? Brand/type? Correct gap? Correct torque?
Any other codes present?
Compression test?
Valve adjustment?
Got a scanner that can display live data?
What are fuel trims at hot idle, and 2500 RPM?
What are fuel trims at idle when it runs rough?
What are trims at highway speed?
Have you tried blocking off the EGR to see if it improves idle?
Pull out the air filter, see if it's a cheap aftermarket, check if dirty, and see if the MAF sensor has anything caught in it
hali0007
Apr 6, 2020 11:27 PM
DavidKing
Nov 9, 2017 08:00 PM
kevykev1969
Dec 21, 2014 05:25 PM
CivicRider
Apr 27, 2014 10:51 AM
Drock22
Jul 2, 2012 01:05 PM
