Popping type noise coming from Suspension?
Old Jul 30, 2017
HondaLuv3r4Life's Avatar
HondaLuv3r4Life is an unknown quantity at this point
I think its coming from the suspension. 187k miles. Whenever going over unlevel ground especially when backing up hear a popping type noise. What could be causes of this?
Old Jul 31, 2017
mac25's Avatar
Dr Krieger of Modification
Re: Popping type noise coming from Suspension?
if it is popping over a speed bump while you are not turning it should be the lower control arm bushings.
If it is while you are turning it could be the upper suspension seats or the ball joints. It could also be the tie rod end links (if it's while turning) but these make a different sound.
Old Jul 31, 2017
The engine mount that goes bad a lot can also make a pop noise on bumps.
You're gonna need to investigate all of the suspension on your own to see what's loose or bad.
Old Aug 2, 2017
or the antiroll bar endlinks
