- 1994 honda civic issues
- how can the oil pan threads be stripped?
- 2010 sport 4door audio issues
- Remove the engine by the top?
- Starter?
- 2004 Honda Civic EX Thermometer Fluctuates
- Honda Civic engine stops while on the go
- Keyless buttons intermittent
- Need a new clutch!!! 2006 civic lx sedan
- Uneven brake pressure!
- 2008 Civic Check Engine Light
- tpms re-sync
- 99 Civic EX distributor wiring harness issue
- gear issue
- Need help identifying a part
- Front End Smashed
- slipping after warm
- 2006 EX Engine Clicking Noise needs new short block?!
- sometimes drops rpm
- Car is noisy/shakes, revs high while accelerating
- 2002 civic battery light issue
- Honda civic '08 tail lights dont work!! HELP?
- 2007 Honda Civic Hybrid system issue, help would be more than appreciated!
- 2010 honda civic ex pcv valve
- Cold start check engine light
- Which Onboard Diagnostic system to buy for Honda Civic 2008
- yet another wacky idle prob help anyone??
- Keep getting rocks behind front brakes splash shield
- Cleaning maf sensor/resetting ecu??
- Oil & Filter Change
- 09 lx-s motor flooding with gas
- 07 newbi check engine PO420
- 2006 replacment of fluids questions
- Red-top in a gen 8 civic?
- 2011 rear wheel bearing bad ALREADY!
- '08 Civic Lights won't go off and remote control does not work
- 99 HX starts for 2 secs then dies
- 07 LX slow coolant leak
- 96 civic pinging
- 2007 Civic starter
- 2006 Honda Civic odd idle at stop?
- Leaking rack 2010 LX
- Timing belt problem honda civic lx 2004
- Used honda civic 2006 1.8 litre s mt problems encountered?
- serpentine belt tensioner bolt
- Possible VTEC oil sensor bad. Please help!
- What's wrong with my civic??
- 2013 Interior Illumination Blue LED Issue
- Manual shift issues
- New 07 civic owner
- high mileage oil type and air bag light on
- noisy clutch
- CEL on my new baby!
- 09 Civic SI Transmission issue, All gears
- How to find official leather color - 2010 EX-L
- 1999 Civic Si EM1 Running Rough Idle with CEL
- E85 in an 09 Civic
- 2007 Civic low speed vibration
- Radio dash light going on and off
- New car(for me), new problems.
- 1998 civic dx smoking like crazy
- 2007 Honda Civic noise, any ideas?
- 07 Alternator needs replacement
- Changing spark plugs on 06 ex non si sedan
- Ebrake handle problem on a 06 ex non-si sedan
- Unique vibrating experience!!
- 2010 civic coupe vibrates on a "P"arking mode
- Noisy ac/heat blower
- 95' civic dx idle problems
- 2008 Honda Civic Hybrid - Oil pan crack
- Wild electrical problems P0111 and others
- 2011 Civic EX manual trans hesitation
- Replacing Driver's Side Mirror
- Non-functioning CD Player
- Driver side Seat Belt tensioners have deployed to a locked position - repair solution
- Wants to stall on takeoff
- swimming pool in my trunk
- Weird clicking noises?
- Trico Force wiper adapter
- converting a sedan exhaust to coupe. worth it?
- Speedometer Error
- Civic 2006 timebelt adjuster bolt keeps breaking
- Poor fuel economy
- Poor fuel economy
- Bumper popped out, Dealer messed it up?
- Cold High Idle
- Gearbox Problem
- Emmision light/ rough ride/ losing gas?
- Odd Whining Noise from 2007 Honda Civic
- Help me find the problem
- 2010 HONDA CIVIC STRUT REPLACEMENT - Does it fall under warrenty
- Coils misfiring? Help!!
- 1991 civic mystery - no heat
- Had a wreck. Little bit of damage?
- Emergency break won't work after maintenance
- '06 trunk- mat and cargo net question
- 2007 Civic EX Cpe Sound Not Working! Help!
- P0171 code/good outcome MAF
- 06 Exhaust silliness
- 97 Honda Civic Oil Burn can someone help??
- 98 civic starting problem after cleaning.
- 07 Civic Vibrates
- Bent axle Or frame on 98' civic! please help!
- Cowling problem on 06 Ex sedan
- 2007 won't turn over, won't take a jump start, all electrical still works
- Private Cloud Training
- 2007 Civic 5 dr brakes not always working
- Old Civic whines at high speeds - On a Road Trip - Help very much appreciated
- what should I do with this tranmission nightmare??
- Honda has extended the warranty on paint.
- Microchip keys, starting/security issue.
- airbag
- PO128 error code, need help!
- 2012 civic ex-l nav system and other screens not bright enough when I start the car..
- Interior panel removal
- Transmission?
- trouble code 2006 civic
- Transmission popping out of gear
- 2010 hard downshift concern
- Underdriven 2010 civic-lx coupe
- Motor mount vibration
- 2006 honda civic lx t boned
- headlight covers cloudy and dash lights out
- imobilizer
- 1996 alternator problems
- 2009 civic battery dead and shaking
- 97 Civic EX having *Terrible* sputter problem.. please help!
- Vehicle codes, what they mean & how to fix them...
- 2010 Civic DX-G Automatic Shifting gears problem
- Rattle noise after acceleration
- Bug stuck in 08 Civic's odometer. How can I get it out?
- 88 Civic with no heat/radio, ignition related?
- Experiencing some pulling when accelerating.
- b16 b18 supercharger
- Totally Stock 2008 Civic LX R18A1 P0303 blinking CEL and hesitation
- New to this, just joined...2006 civic maybe hydro locked
- A/C problem TOOOO
- 2001 si/computer is finished and car puffs
- 01 Civic High rpm no acceleration
- 07 Rear Suspension
- '00- Need help installing RPM Tach
- Skunk2 CAI problems
- ac compressor clutch problems
- Gas mileage problem - 2006 Civic EX - Auto Trans.
- 2006 Civic - CD player won't work
- 2011 Civic Fuel Fill
- Smoke from driver console
- Honda Civic 2010 LX - how to reset SRS/airbag light?
- civic 2011 engine stop when park
- 2006 Civic Coupe problem starting
- Curtain air bag
- Need ideas / help on problem
- spends much fue
- 07 lx coupe reverse noises on inclines
- D15B lost all power!!!
- 2012 Coolant
- Weird static-like noise from passenger air vent
- newbe needs help!
- Overheating after ~2 miles, running out of ideas
- Door panels melting from back side?
- 2007 Hybrid - Battery/IMA/Electrical Issue
- I have a rattle inside my passenger door.....
- 06 A/C Issues
- 2007 Civic LX coupe transmission stutter.
- how to replace fuel door latch
- 09 Civic LX Question
- Intermittently Overheating
- 01 Civic EX check engine light
- 08 Civic LX interior trim letter?
- 2007 LX horn and cruise control issues
- Loosing power
- Honda 08 won't run over 1.5RPM
- can't get over 5mph
- 07 civic lx shuts down when slowing down
- 2007 honda civic si that wont start unless it is pushed
- 2007 driver side exhaust noise but not from exhaust
- 08 Coupe Manual Transmission AC issue
- 07 civic LX cruise won't remain engaged
- 08 civic oil?
- 08 Honda civic lx issue..
- Car does not start, possible immobilizer problem
- 2011 Honda Civic Transmission Fluid
- Engine heat-up; passenger side fan doesn't work
- '07 DX-G Radiator Replacement
- 06 AC problem
- 2006 Serpentine belt size problem
- 2009 EX-L Low speed thunk/clunk noise in tight turns
- 2002 Honda Civic EX while driving tries stalling
- 07 si clutch
- reverse problem on my 2007 2dr ex
- brake problem
- 2009 -Condenser and Radiator Fan not starting
- a few major problems
- Flush the Transmission on a manual??
- CD Player Problem
- Idle Adjust
- New here and need some help 2000 civic ex
- 2007 Civic Si Horn not working
- stereo problem help
- Brake, Power Steering, and Trans Fluid
- Cabin light on drain battery over night?
- 2007 Civic Gas problem
- Rough Idle when car stopped ...
- 06 Civic Drip Molding Removing & Install
- Engine Shakes and exhaust is sputtering
- 2009 Civic DX - Front Bumper Loose
- How old do these spark plugs look?
- 09 Civic LX sedan, rough idle and stalled at stop
- 06 civic rattle/burning rubber smell
- Honda civic 09 ex coupe. Cant figure out this part
- 2007 LX Oil Leak
- Yet another door chime issue (2007 EX)
- P1298 and P0420
- helpp honda civic si 2006 oil meter
- Freeze Frame data, any ideas?
- Oil problems please help
- Help! My 06 Ex tire problem
- 2003 honda civic with P1298 problem
- car starts and stalls after 3 seconds
- 2010 low rumble at idle
- 2006 LX needs help
- 06 EX Valve Lash Adjustment; lost Eco, idle and power! Help!
- check engine light
- DIY Motor Mount
- What do i need to look for on this car?
- 06 Civic turns over slow, then only clicks
- Rounded AND Stuck oil drain plug
- 2007 civic..loud sound..any suggestions
- 07 Civic Won't Start, Where to Start?
- 2012 Civic EX Icy roads
- 2008 civic lx growling noise
- Alternator question
- my back up lights dont turn on when i put it in reverse !!!!!
- 2006 Civic - need to replace muffler
- 2006 Civic EX - AC Fan Stopped Blowing Air
- Need help in part ID plz!!
- Transmission Flush 2006 Civic EX - Help
- side mirrors fogging up
- 2009 Honda Civic LX
- Civic 2007 fluid leak
- Use a Shorter Drive Belt?
- heater issue
- 2008 Civic Problems
- How to remove rear bumper cover 2012 Civic???
- b18b1 civic no spark. please help!!
- 08 civic AC bearing replacement
- Auto Transmission In The Cold?
- 2011 Civic oil leak
- 08 civic LX - Oil leak from engine breather cover (rear)
- 2008 Civic - Needs new clutch - suggestions please
