Transmission popping out of gear
Old Oct 10, 2012
05_HondaCivic's Avatar
05_HondaCivic is an unknown quantity at this point
i recently just replaced the mainshaft bearing on my 2005 civic ex. when i put everything back together i think i tightened the shift fork detent bolts down waaay to tight and the ball bearings are stuck inside the bolt..would this cause it to keep popping out of gear..its okay in 1st and 2nd..but 3rd and 4th will pop out? how tight should they be when i replace them?
Old Oct 11, 2012
Largen's Avatar
Largen is an unknown quantity at this point
Re: Transmission popping out of gear
Well more play from them being overtightened can def be a possibility, as for a torque spec I imagine it will be in inch/lbs and will be found in any decent manual
Jul 12, 2015 11:54 AM
fvckbg
Jul 7, 2015 07:08 PM
wholt0
Transmission
Jun 11, 2015 11:15 PM
cruisers10
May 12, 2015 10:46 PM
01CivicEXs
Transmission
Jan 21, 2002 09:55 PM
