car starts and stalls after 3 seconds
Re: car starts and stalls after 3 seconds
Hello Levi22.
Have you checked the fuel pump relay? The smell to burned plastic and the fact that the engine dies after some seconds makes me think about that possibility. I hope my comment helps.
First: Got codes? That would be a good starting point.
3 possibilities come to mind...
A) When it dies is the green key light flashing? Immobilizer problem.
B) Alternator bolts loose.
C) Unplug the cam position sensor and see if it runs longer than 3 seconds now. If it does then shut it off at 5 seconds and tear off the front of the engine, the cam is out of time by one tooth or more and you have a serious problem that needs figured out ASAP.
The burned plastic smell makes me think C will be your answer. Is there a clattering noise that goes along with this?
HTH
HTH
dragonsblood
Apr 27, 2015 12:28 PM
McD
Apr 22, 2015 05:28 PM
Blaster30
Apr 22, 2015 12:21 PM
McD
Apr 16, 2015 10:46 AM
