PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 [3] 4 5
  1. Does my car even have an alarm???
  2. Exterior Seals
  3. 2010 AC Failure
  4. 2007 civic coupe
  5. 06 Civic EX Not Starting - Any Suggestions
  6. 2008 Honda Civic Hybrid thumping noise when accelerating from stop.
  7. Possible Transmission Problem
  8. Bizarre texture along bottom of car
  9. Anyone good with bumpers?
  10. 07 civic ex power loss check engine light on
  11. 2010 Honda Civic LX 4 Door. Making Noise
  12. Air problems?
  13. 2007 civic coupe- leaking oil on incline
  14. A/C lemon
  15. Problems with door locks - 2008 Civic
  16. An Influx of OBD codes
  17. 2009 Honda Civic EX Coupe Firewall
  18. 08 Civic - noise when turning the steering wheel
  19. 2015 Civic radio will not come on, and key won't unlock door
  20. New Civic Owner - Noises when shifting?
  21. Car wont hold charge/over charging
  22. My timing skipped - are my valves ok?
  23. Two questions about my new Civic
  24. Dealer or Independent Service
  25. 2014 Honda Civic LX CVT Sedan Vibration--Less than 10k miles
  26. 2008 civic lx - Tensioner/pulley noise
  27. 2007 Honda Civic Manual: 1st Gear rattle noise
  28. 06 EX Sever Tensioner Failure
  29. 2007 hybrid civic sedan - a/c very noisy
  30. Code P0756 Shift Solenoid B Performance or Stuck Off
  31. '06 civic accessory belt won't turn but motor runs
  32. HELP! My 2nd, 4th, 6th and reverse gears don't engage but my 1st, 3rd, and 5th work
  33. Loose steering and bad acceleration after hitting potholes
  34. Gas mileage in 2009 Honda Civic
  35. Clunk Knock Noise Front RH Civic 8th Gen
  36. Vibration at Idle.? 2006 civic 1.8
  37. Civic 8th gen Sedan: Clunk Noise from front RH
  38. Car won't start, power issue
  39. Damaged clear coat
  40. no rear running lights
  41. Please HELP! Car won't start!
  42. help with noise issue
  43. [SOLVE] 06 Clutch will not disengage,Master/Slave does not appear to leak, fork moves
  44. 2008 lx parasitic draw
  45. Part number for drive belt for 2007 Civic
  46. Need help finding VSS sensor
  47. cranks slow when cold
  48. Lower engine torque rod engine mount and rear upper control arm
  49. How to Fix Error Codes P2185, P2183, P0111, and P0128 on a Honda Civic 2006
  50. power steering or AC unit
  51. Front end grinding noise
  52. Issues with Starter/Temperature Gauge
  53. 2011 Honda Civic Ex AT
  54. 2014 fluid leak 3K miles :(
  55. Bushing Civic 2005 compatible with civic 2007?
  56. Idler pulley replacement
  57. erratic shake
  58. 2008 Civic Transmission Range Switch
  59. 2006 @ 200k What needs replaced?
  60. Replacement key???
  61. 2006 civic A/C Continuous cycling on and off.
  62. 98 civic ex, power problem
  63. Unhappy 2002 civic lx wont start
  64. 2014 Tire Pressure Sensor
  65. Lower Radiator Hose Help
  66. brighter backup lights
  67. Car alarm malfunctioning
  68. Hi It's Kim im new.. My 2008 civic ~ the Fan Motor Dying :(
  69. poor gas mileage 2014 civic EX
  70. At stop light started making a loud rumble from the back is it safe to drive?
  71. P0849 transmission fluid pressure sensor /switch B circuit intermittent
  72. Help: Changed mounts but still have interior vibration
  73. unusual engine rattle .. at idle . 2008 ex
  74. Occasional starting problems
  75. Strange Squeak and TPMS
  76. Auto Prestige BC - Mirabel Quebec Canada
  77. Break light on the driver passenger side does not work
  78. Oil cap exploded...
  79. slave cylinder repair
  80. Resolving constant "on" AC problem <-- SOLVED!
  81. Car Shakes at High Speeds
  82. 08 Civic Lx - 67K - Roller/Belt noise
  83. IMA light
  84. Which Fluids New 1.8L Civic
  85. ac cold, but turns warm
  86. How much to replace the aircon unit??!!??
  87. 01 Civic LX misfire won't go away
  88. 08,A/C cycling pressures
  89. 2008-20011 Civic
  90. drl issue
  91. Valve cover gasket for 2010 1.8l
  92. 96 civic dx speedo problems...HELP!!!
  93. drl
  94. my experience with the engine malfunction light
  95. coolant system issues in 04 civic
  96. 2011 EX-L Trans. Fluid Change
  97. 2007 EX 110k miles transmission shudder
  98. 09 civic si help!
  99. this weird noise on my civic 2008 ex ,,, coming from near oil pressure sender ,,,
  100. AC Dilemma
  101. 2005 1.7 no spark won't start
  102. Radiator fans
  103. Weird 2006 Honda Civic 4-Door A/C Issue
  104. Help!!! - Rear Camber Kit - 2007 Si Sedan
  105. P0847 Transmission Fluid Press Sen
  106. 2007 Civic A/C
  107. Rear Wheel Bearings
  108. 2008 4 door civic parts
  109. 2007 Civic Starting Problems - (No Crank, Clicking coming from under steering collumn
  110. 2009 AC cool then not. Not cool.
  111. 2010 Automatic Transmission Oil Change
  112. Minor items in a 2014 Civic LX
  113. Bad battery or failing alternator?
  114. salvage title mystery
  115. 2012 Civic LX fuel gauge problem?
  116. 2012ex Performance issues
  117. A/C Puzzle...Need Help
  118. Removal of AC compressor
  119. 2006 Civic Si Radiator Issue?
  120. 2006 Honda civic EX coupe
  121. 2006 1,8l Wont Run
  122. 08 Civic LX - 65K - Serpentine belt/Tensioner squeak noise
  123. 2007 Civic SI Shifting Issue
  124. 09 Honda Civic wont doest start
  125. IMA light 06 HCH
  126. '06 Civic Si
  127. Passenger door panel help
  128. 2009 honda civic horn problem
  129. 2010civic heat / a/c blend door
  130. 2008 civic battery keeps discharging
  131. Engine Light on. Please help
  132. 2002 Civic Ex Misfire codes
  133. Do I need a new trunk? 2008 Civic Sedan
  134. Rattle in drivers door
  135. Drive Belt Tensioner 2007 Civic LX
  136. Timing belt blew, fixed it by car won't fire up.
  137. 2007 starter
  138. Phantom DRL's
  139. 2008 EX Broken Motor Mount
  140. A/C trouble
  141. location of starter relay on 2011 honda
  142. Auto tranny fluid change
  143. Water in gas tank! Please advise
  144. Tranny silp? or something else?
  145. Fuel Filter location on a '07 Civic
  146. To those who use seafoam I have a question
  147. Can't find a downpipe for 2011 lx
  148. civic makes noise and stalls. NO check engine lights
  149. Hybrid Battery
  150. 06 slow to heat up
  151. 2007 Si won't start
  152. 07 Si won't start please help!!!
  153. Check Emission System
  154. Car overheated cranks but would start
  155. 2007 Sedan EX Hesitation
  156. 2007 Hybrid Oxygen Sensor
  157. 09 Civic EX Coupe Trembling Issue on Reverse
  158. whining noise while reversing
  159. Check engine and IMA displays come on
  160. Help fuel pump civic 2007 coupe
  161. Starting
  162. 2007 Honda Civic Squirelly when I hit a bump.
  163. b18b turbo
  164. battery replacement procedure
  165. Engine wont Start due to Cold weather - Heat gun on engine? '06 lx automatic
  166. Honda Civic 2008 sudden high RPM
  167. 2009 Honda Civic DX fuel mileage concerns..
  168. When to replace battery
  169. Broken Nuts Problem
  170. 2010 Civic brake fluid change question
  171. 2008 Civic starting issue
  172. Battery (Charging) Light Problems
  173. Help for an ignoramus
  174. Can't Figure Out What's Wrong (multiple Problems)
  175. 2007 civic a/t acceleration issue
  176. Engine sounding weird [honda civic 2007]
  177. Please help! 06 civic Hybrid transmission fitment!
  178. 2006 SI rattling when accelerating after gear is engaged
  179. The wonderful world of not stopping
  180. 2008 vibration 900rpm to 2200rpm
  181. 2007 Si Torque Steer
  182. 2010 changing the coolant
  183. Automatic Tranny Fluid Level Overfilled?
  184. WTS New:Numark NS7II..$700...Pioneer DDJ SR...$400..Behringer X32..$1500
  185. Clicking Sound When Turning
  186. 2009 Civic hissing/grinding noise
  187. Lower Airbox Knocked Off.
  188. Honda civic 2013: HELP NEEDED!!!! Please and thank you!
  189. Feeling Tachy
  190. Does the exhaust pipe sound normal?
  191. serious problem please help
  192. 2008 Honda Civic Hybrid New AC Compressor
  193. 2010 civic door lock problem
  194. ATF Leak
  195. NO START HONDA CIVIC 94 desperate need of help
  196. 2006 Civic weatherstripping Huge problem.
  197. Check Fuel Cap?
  198. Battery charging / discharging rapidly issue (with video)
  199. Civic 2012 Power steering groans
  200. European model - missing plate on underside
  201. Coolant reservoir empty? Car running fine..
  202. Clutch pedal loose??
  203. Civic Spoiler on Accord Coupe
  204. ignition timing D16Y8
  205. 2010 Sedan Seats. Hope you guys can come through for me!
  206. 2013 civic A/C issue
  207. New to forums and Hondas. Issues with battery
  208. coolant filled up to cylinder walls
  209. rattle noise at idle with ac on
  210. 2006 DX - rough manual shift
  211. Need help with engine noise
  212. Spark pluge change issue please help!
  213. bike rack receiver hitch or strap on
  214. 2010 sedan
  215. 2013 civic lx oil change problem
  216. Rough Idle
  217. 2009 Honda Civic, start issue, idle issue, AC issue?
  218. speedbump Clunk on passenger side.
  219. Switch
  220. Passenger Seat is Stuck
  221. 08 EX Tranny fluid
  222. 2009 Civic - Ran into small boulder
  223. AC of Honda Civic 2008 not working perfect
  224. Thermost 92 Honda Civic Dx 1.5L
  225. AC issue
  226. Technical issues with my 97 dx, need some help/ advice.
  227. Starting issue - Not sure what to get looked at
  228. Is it the tumbler?
  229. hard to shift into 2nd gear
  230. Problems shifting into 1st gear
  231. Removing Outside Door Handle on 2008
  232. AC problems!!
  233. A/C Compressor clutch rattling!!!
  234. 2007 stalls when idling at intersection
  235. Noises and Leaks...Please HELP!
  236. Uneven or Rapid Tire Wear Class Action
  237. Anyone good with bumpers?
  238. loud whirring/whining/grinding noise 87 civic
  239. 2006 LX Compressor replacement Questions? plus a story? :)
  240. 2008 Civic A/C Condenser fan issue
  241. Need help with a huge dent!!
  242. Found this rubber valve piece in my stock air intake
  243. 2007 AC Compressor Replacement
  244. 1994 engine into 1998 civic
  245. 2012 honda civic battery
  246. 1994 honda civic issues
  247. how can the oil pan threads be stripped?
  248. 2010 sport 4door audio issues
  249. Remove the engine by the top?
  250. Starter?
